EOC at night - Fuelly Forums
Old 02-18-2009, 08:37 PM   #1
EOC at night
I was just wondering if you guys EOC at night. I just wonder if it will wear out my battery faster having the lights on and EOC. I can still see just fine but the lights do get dim while I EOC. Thoughts?
Thanks
GasSavers_tbone is offline   Reply With Quote
Old 02-19-2009, 04:18 AM   #2
I don't EOC, but I have shut the engine off @ traffic lights. I do sometimes get scared sitting with my lights on, but I've never had a problem. I do it a lot less frequently at night though.
Old 02-19-2009, 05:39 AM   #3
I do EOC at night. So far, I haven't observed any problems. The car doesn't seem to suffer.
AFAIK, small discharges like that won't wear the battery any more than keeping it full, and modern cars even cycle their alternators on/off and run on the battery when the alternator is off.
Old 02-19-2009, 10:46 PM   #4
DRW
I EOC at night and sit at stoplights with the lights on. Fortunately I have a long commute, so the battery has plenty of time to charge.
I've replaced all running lights with LED's to reduce the drain on the battery.
Dave W.
Old 05-31-2009, 08:09 AM   #5
as long as its not a 10 mile downhill it should be on..lol.. its actually good for your battery to have deeper discharges sometimes, and also good for the alternator to have to charge it back to a peak state. you definately need to check your battery and alternator before doing this, you can buy a multimeter from radioshack pretty cheap.
nate sanders
the less throttle you give, the more mileage you get!
hi tech hillbilly is offline   Reply With Quote
Old 08-16-2009, 01:39 PM   #6
Thanks
I would imagine that it is fine. The alternator will make up the extra juice while the motor is running. You should be able to run your lights for several hours without them even dimming, so even 10 or 15 mins is pretty meager to the battery's potential.
soda_pop503 is offline   Reply With Quote
WTB Civic VX near WA slogfilet Wanted to Buy 5 04-29-2008 12:24 AM
Anybody using veg oil in/near Vermont? oneinchsidehop Diesels 2 01-30-2008 08:25 AM
Any jeep cherokee owners out here? GasSavers_rav Aerodynamics 5 01-17-2008 04:18 PM
ROFL. Anybody see General tech??? Compaq888 General Discussion (Off-Topic) 15 09-03-2006 05:04 AM
going to Japan for a few weeks GasSavers_Diemaster General Discussion (Off-Topic) 8 05-21-2006 12:17 AM
