Eoc - Fuelly Forums
Old 07-02-2008, 03:37 AM   #1
goofy1's Avatar
Eoc
i was reading my cars maunal and it says that the car when towed should not be towed with the front wheels on the ground, because of serious damage to the transmission. So i take it that EOC is out of the question so i don't mess up the tranny, right? and if so is there another option besidies pulse & glide in gear?
"But Doc, we dont' have enough road to get it up to 88 miles per hour"
goofy1 is offline   Reply With Quote
Old 07-02-2008, 03:43 AM   #2
You can shift into N without shutting off the engine. This keeps the fluid pumps operating in the transmission.
Old 07-02-2008, 11:35 AM   #3
goofy1's Avatar
well i tried that for a week, shifting to n and coast with the engine on and i got worse mpg. so i stopped that.
Old 07-02-2008, 11:49 AM   #4
kamesama980's Avatar
your car is new enough to have DFCO hence the worse mpg.
Old 07-02-2008, 01:38 PM   #5
If you have an automatic, then dont coast in Neutral.
I dont know why people on here say it is okay... maybe they are rebuilt transmission salesmen.
1996 Protege DX- stock
Advice to readers of this board:
If you have an Automatic Transmission, then do not coast in Neutral.
grey is offline   Reply With Quote
Old 07-02-2008, 01:43 PM   #6
palemelanesian's Avatar
Coasting in neutral is FINE if the engine is running. No problem whatsoever. Automatics will frequently do this on their own. Just watch the tachometer drop to idle as you roll up to a stop - that's neutral.
In this case, coasting with the engine off is bad. Just make use of what you can do. I suggest trying engine-on coasting again. It's amazing how little bits of 150mpg will raise your trip average.
You might consider a Scangauge to show you how and when to use this, though.
Old 07-02-2008, 02:01 PM   #7
It may be that it won't work for you, or you may not be using the strategy right. It can be a little confusing trying to find right the way to use it.
DFCO is not a substitute for neutral coasting. They're complimentary. DFCO is great if you intend to slow or stop. Neutral coasting is better if you don't.
See, you have a certain amount of kinetic energy stored in the car, and idling uses a certain amount of energy stored in fuel. When you DFCO, you use your stored kinetic energy not only to move the car, but to turn the engine a lot faster than necessary, pumping air past a closed throttle and fighting engine friction. When you neutral coast, you use less energy all total; the amount of gas you spend idling is less than the amount of gas you'd have to spend later if you had chosen DFCO instead.
I don't know where this FUD comes from...maybe from oil salesmen. There is no reason why neutral coasting in an automatic would cause a problem. The issue was thoroughly discussed in another thread:
http://www.gassavers.org/showthread.php?t=8150
I don't know where this piece of misinformation continually comes from either. Check the same thread I link above. Automatic transmissions do NOT enter neutral unless you shift to N. They remain in gear, and the torque converter unlocks; it still transmits some power, but the fluid coupling allows the car to be stopped while the engine continues running. This is why it saves gas to put it in N while stopped instead of staying in D. I've watched my fuel rate meter in my automatic as I wait at a stop in D and N, and fuel rate definitely goes down in N while RPM stays the same.
This part is 100% correct.
Old 07-02-2008, 02:10 PM   #8
I've seen the same. I was (unclearly, you're right) talking about as you're moving at, say, 20mph. It's not the same as neutral, but the effects are similar. Engine and wheels are moving at different speeds, and the transmission is just fine.
Old 07-02-2008, 02:23 PM   #9
Even then, in most vehicles, the engine won't go all the way down to idle. In fact, even in N while at speed many won't go all the way down to idle (due to fluid resistance inside the transmission, I think).
The effect is similar but it doesn't demonstrate the safety of neutral coasting. Nonetheless, neutral coasting is safe in common automatic transmissions. I've never ever heard of anyone for whom it caused a problem.
Old 07-02-2008, 02:55 PM   #10
oh well, highly scientific research is hard to dispute...
ask a person who knows, such as a reputable transmission mechanic.
WTB Civic VX near WA slogfilet Wanted to Buy 5 04-28-2008 11:24 PM
FS: 1993 Honda Civic VX // Clean // Stock // Super Gas Saver WTBCivicVX For Sale 2 03-18-2008 04:20 PM
Anybody using veg oil in/near Vermont? oneinchsidehop Diesels 2 01-30-2008 07:25 AM
Any jeep cherokee owners out here? GasSavers_rav Aerodynamics 5 01-17-2008 03:18 PM
ROFL. Anybody see General tech??? Compaq888 General Discussion (Off-Topic) 15 09-03-2006 04:04 AM
