Comment on P&G - Fuelly Forums
Old 07-26-2007, 05:46 PM   #1
Comment on P&G
I don't know if some already talk about this on the forum, but I have a question on this Pulse and Glide technic. Yes it's good in theory and all, just like when I'm going downhill I WAS putting my VX in neutral. But then I thought about that, when the car is running in neutral, the gaz isnt burning the same way then if it would be in gear, so I told myself, well I'm better be in gear, even if a burn a litle bit more gaz, at least its going to be more clean for the air.
So what do you, people of gassavers.org have to say about this, because I really dont know what to think.
Old 07-26-2007, 05:48 PM   #2
omgwtfbyobbq's Avatar
So long as the engine is running, your emissions system will still inject enough fuel to keep the catalytic converter/s running as they should be, so there shouldn't be any change in emissions. In fact, your emissions will be proportionally less w/ the car in N provided you're getting however much better mileage. When you shut the car off, the cat/s can cool down to the point where a significant rich excursion is required on startup, which would result in more, possibly way more, HC emissions. So unless you kill the engine, your emissions should be roughly the same.
Old 07-26-2007, 06:22 PM   #3
Well I know what I'm going to do, shut off the engine when I'm going downhill! On a 70km trip, I'm doing like 5km, at least, on downhill. This is going to be a great save of gas, of money and also the mileage of the car, even if I don't think I never will sold this VX.
First fill up on brand new car? kwakaman Fuelly Web Support and Community News 1 02-10-2012 06:49 AM
poor mpg dremartinez General Fuel Topics 10 01-10-2012 10:39 PM
SG for the House zpiloto General Discussion (Off-Topic) 5 05-08-2007 08:01 PM
Roof Rail drag GasSavers_nemo Aerodynamics 1 04-07-2007 04:21 PM
Grille block success GasSavers_James General Fuel Topics 11 01-26-2007 05:59 PM
