Coasting Problems - Page 2 - Fuelly Forums
Old 02-10-2007, 06:44 AM   #1
Coasting Problems
If you'd like to diagnose the problem a-la "CarTalk Puzzler" style, try to avoid reading below the solid-line)
It's been about 2 solid weeks since I've driven the Integra (1-week in the shop, and out of town about a week).
I head-out this morning to get my morning fuel (coffee ) and I take the same route I generally do when going to work, etc.
Using the same techniques as always, I engine-off coast down the larger hills and some light grades. But for some reason, it was just coasting to a near stop -- half the distance it used to.
After checking the tire pressures, all 4 were fine. It wasn't until I got back to my garage at home did I smell the problem.
(I was listening to CarTalk so if you'd like to make this a "Puzzler", be inspired to do so )
__________________________________________________ _______________
Well, it turns out to be a sticky brake. I'd know that burnt smell anywhere. So, now what do I do? I assume that I have to identify which wheel is the culprit by either sniffing around or jacking-up the car (chocking the opposite wheels) and seeing which one doesn't turn in neutral. The setup is front disks and rear drums. I use the parking brake often, so the rear drums should have self-adjusted (should I do a hard stop in reverse to confirm adjustment?) I've changed brake pads in the past, but a sticky caliper or shoe is new to me...
EDIT: I stand corrected. The car has small, rear disc brakes. I found the source -- it was a hot and smelly rear driver's side disc. It's definitely dragging.
Two stroke oil in diesel Eybrows General Fuel Topics 16 01-27-2013 08:20 PM
Fuelly Moving to New Servers pb Fuelly Web Support and Community News 4 11-30-2011 09:31 PM
long time MPG nut JanGeo Introduce Yourself - New member Welcome 8 01-23-2006 02:33 PM
Parking Brakes and Fuel Economy? Matt Timion Automotive News, Articles and Products 0 10-03-2005 01:23 PM
