coasting - Page 4 - Fuelly Forums
Old 03-29-2006, 05:36 PM   #31
i have read (can't remember
i have read (can't remember where) that OEM tires (like i have) are different than aftermarket replacement tires of the exact same brand & model. the original tires are supposedly more lightly built and may return better fuel economy.
anyone else heard this?
Old 03-29-2006, 07:13 PM   #32
Re: i have read (can't remember
I know lots of people that buy OEM tires for vehicles 5+ years old. The problem is that today, on the average of every 2 years, breakthroughs in tire technology yield lower rolling resistance, better traction, handling, etc. I'm sure that the OEM tires will become less expensive until they become rare, then an alternative will be the only option. As far as weight, that may be a misnomer.
For me, my personal research has shown that simply for improved safety (wet and snow) in addition to better economy and handling, I'll find the newer design that fits and put OEM behind me. I've never used OEM as a replacement tire on 8 vehicles over the years.
Old 04-07-2006, 07:36 PM   #33
GasSavers_Ryland's Avatar
I've noticed that alot of
I've noticed that alot of new cars come with tires that have a low wear life, and that they are normaly a cheap tire, why? because very few people are going to complane about having to replace their tires after a few years, it's one of those normal things you do with a car, so very few people notice cheaper tires, of course some of them are also chosen because they boost the MPG by just enough to get that EPA rating knocked up a notch, either by useing a harder rubber, or making them out of less rubber and steel belting, but I've noticed a number of OEM tires that have a wear life in the area of 180-240 and look at what else is avlible in that size and they are in the 380-440 wear life...
Old 04-11-2006, 04:30 AM   #34
philmcneal's Avatar
damn its funny scangauge has
damn its funny scangauge has the same distance in the trip view when comparing to my car's tripA(reset when filling) odometer. So I'm pretty sure my car's odometer is still regestering after keying off but I'm having the delay that metrompg used to have before although not as long (5 seconds). But still that's enough to mess up data if you do it enough. What I also noticed when I switch data from km to miles and litres to gallons, the conversions work out all right except for gallons which still show an awfuly big number since it wasn't touched at all.
Setting the hybrid mode on the scangauge at least it won't turn off, but data still freezes... distance is still recorded but fuel economy trip resumes after 5 seconds later skewing the data. Hopefully recalcuating by hand will save the day. Bleh how hard can a kill switch be? am I going to be running into any problems if I have an engine immobilizer?
Old 04-19-2006, 09:18 PM   #35
tomauto's Avatar
Send a message via AIM to tomauto Send a message via MSN to tomauto Send a message via Yahoo to tomauto
clutch starting
How do you go about "clutch starting" exactly? This sounds interesting.
Current Stable
tomauto is offline   Reply With Quote
Old 04-20-2006, 02:25 AM   #36
krousdb's Avatar
Re: clutch starting
While moving, choose the appropriate gear for your speed and let out the clutch. Usually the highest gear will provide the least amount of commotion.
Old 04-20-2006, 03:51 AM   #37
pop it
actually you should pop the clutch quickly then push it back in to just give the engine a spin to start in a high gear then shift to a lower gear to match the rpm to speed. Just letting it out can be hard on the gears if the engine rpm is too low to run smoothly.
Old 04-20-2006, 08:56 AM   #38
tomauto's Avatar
clutch starting
So you dont have to turn the key? The car just springs to life?
Current Stable
Old 04-20-2006, 09:47 AM   #39
krousdb's Avatar
Yes, as long as the ignition
Yes, as long as the ignition is on. I kill the ignition to coast and then switch back on immediatly (as soon as the engine dies) so the odo/speedo will record distance. You can clutch start any time after turning the ignition back on.
Old 04-20-2006, 04:28 PM   #40
tomauto's Avatar
clutch starting
How long have you been doing clutch starting?
Current Stable
Two stroke oil in diesel Eybrows General Fuel Topics 16 01-27-2013 09:20 PM
Fuelly Moving to New Servers pb Fuelly Web Support and Community News 4 11-30-2011 10:31 PM
Using the "Engine Load" number from OBDII... GasSavers_root General Fuel Topics 5 07-01-2007 07:06 AM
Switchable power steering idea dieselbenz Introduce Yourself - New member Welcome 11 03-08-2007 05:58 PM
Parking Brakes and Fuel Economy? Matt Timion Automotive News, Articles and Products 0 10-03-2005 02:23 PM
