where to find a drycell - Page 2 - Fuelly Forums
Old 06-22-2010, 08:45 AM   #11
Dr. Jerryrigger's Avatar
Originally Posted by mikehallbackhoe View Post
I am curious how they decide how much hho to use. I have also read .5 to 1 per liter. , but I have also read .25 to .5 L. does that take into account how much horsepower. for example, to determine carb. cfm, you take the engine size, and the rpms , and my engine is a low rpm, low horsepower engine. is there a problem with running too much hho? . My truck has a very large , heavy duty alternator, so it could probaly handle more hho without stressing the electrical system. My engine is gasoline, by the way
Oh, I just assumed it was diesel. I guess it would make sense that you would need less HHO per L if you are running at low RPM.
It's hard to tell what is best. People who have tested HHO have all done so under different driving conditions, with different styles of driving.
As far as too much HHO, I don't think you could have too much, but there is a point where is starts to make your FE lower. An HHO system takes more energy to run that it makes, so you're loosing engey. The savings come from better combustion of the petroleum fuel. No one has figured out the ideal ratio, just things that seem to work. I think the best way to set up a cell is to have a PWM controller that automatically adjusts for engine speed, and or throttle position, and or vacum pressure. This way the HHO is more proportional to the fuel used.
Old 06-22-2010, 04:24 PM   #12
as far as losing energy, I am considering adding an auxillary battery, and charging it at night with a battery charger. much more efficient than using the truck's charging system,and the extra weight won't effect the truck. this would also require less hho, since it wouldn't rob any energy from the truck.
mikehallbackhoe is offline   Reply With Quote
Old 06-23-2010, 07:51 PM   #13
That is a good idea, but an HHO system quite voltage sensitive, so a bat that is draining, and there by changing voltage may not work as well. If I would suggest going with a lot of bats, set up so you can plug them in to a charger with out removing them, or connecting them to your charging system, but also charging them at night.
Old 06-23-2010, 10:25 PM   #14
I rarely run the truck more than a few hours a day, mostly to haul my backhoe to a job, and then to bring it back. do you think a couple of marine batteries would do the trick?
Old 06-24-2010, 07:47 AM   #15
yeah, that should work. If you get a cell that is made for the lower end of the voltage you'll be working with, everything should be fine.
Actual Savings FXSTi Fuelly Web Support and Community News 6 01-09-2012 08:49 AM
Chevy Volt Mark0 Fuelly Web Support and Community News 2 12-18-2010 05:50 AM
DIY: Make a PVC Catch Can for your PCV System GasSavers_TomO Experiments, Modifications and DIY 7 07-12-2008 03:24 PM
bike rack McPatrick General Maintenance and Repair 4 08-07-2007 07:34 AM
Honda CRX HF Gearing ...and/or engine swap Brian D. General Fuel Topics 36 09-06-2006 06:09 AM
