water injection (not hho) - Page 2 - Fuelly Forums
Old 08-05-2008, 10:45 AM   #11
...of course, at 180psi, it takes a whole lot more heat to boil water.
Old 08-05-2008, 10:58 AM   #12
thornburg's Avatar
DUH...
Here I go acting like the inside of your engine is operating at STP....
Old 08-06-2008, 11:59 AM   #13
trautotuning's Avatar
HEAT THE WATER BEFORE!
It will actually help the combustion process since it will give more oomph to the intake (aka WAI).
I plan on doing this in the very near future, and I am convinced it works, but the water has to be heated (I will wrap it around the exhaust manifold).
Old 08-06-2008, 12:02 PM   #14
Oh, not only that, but it will also keep your engine (intake, piston chamber, and exhaust) extremely clean so there will be very little drop in milage as the car gets older...
Old 08-06-2008, 12:19 PM   #15
Doesn't the WAI work because it increases the throttle opening you need to get the same amount of air into the cylinder reducing your intake manifold vacuum? Warming the air after it enters the intake manifold wouldn't give you that benefit would it?
- Kyle
Old 08-06-2008, 12:51 PM   #16
It would, you have to open the intake more because there is essentially less power (less fuel in the piston chamber because the air is expanded more). So it would not matter where the air is heated.
However, it shouldn't even matter in this case because you want to inject the water at least 6" BEFORE the throttle body in order for it to be able to completely mix with the air.
Old 08-09-2008, 02:47 PM   #17
GasSavers_maxc's Avatar
Check out this water injected engine. http://peswiki.com/index.php/Directory:Gun_Engine
less lurking and more working
Old 08-09-2008, 02:58 PM   #18
It has to matter where it is heated, if it didn't matter then none of us would need WAI because a hot engine has a pretty steamy intake manifold and combustion chambers as it is.
- Kyle
Old 08-09-2008, 03:00 PM   #19
HELL YEAH that's what im talking about!!! 8:1??? and i was talking 1:2 and people thought I was nuts.
ziddey is offline   Reply With Quote
Old 08-09-2008, 03:21 PM   #20
No your not nuts. I know a guy who ran direct cly injection of water at 300C at 3000psi. Almost blew the head off the engine(streched headbolts, wasted head gasket,cracked piston. He ran 10 to 1.
More detail josh434 General Fuel Topics 2 06-28-2009 03:39 AM
A shot with a mix... GasSavers_SD26 Diesels 23 03-13-2008 06:20 PM
How to FE drive when OAT is hot? GasSavers_rGS Hypermiling 3 07-19-2007 03:35 PM
Crazy Spark Plugs Claim Increase of 50% in Gas Mileage SVOboy General Fuel Topics 13 12-29-2005 06:36 AM
