Something different... - Fuelly Forums
Old 04-24-2011, 05:36 AM   #1
I haven't heard of this before.
Apparently it is onboard hydrogen generation that consumes metals as fuel. The energy source would seem to be the consumed metals, which would make this different from simply trying to use energy to split water.
http://www.isracast.com/article.aspx?id=43
Originally Posted by excerpts from the article
A unique system that can produce Hydrogen inside a car using common metals such as Magnesium and Aluminum was developed by an Israeli company.
The Hydrogen car Engineuity is working on will use metals such as Magnesium or Aluminum which will come in the form of a long coil. The tip of the metal coil is inserted into the Metal-Steam combustor together with water where it will be heated to very high temperatures. The metal atoms will bond to the Oxygen from the water, creating metal oxide. As a result, the Hydrogen molecules are free, and will be sent into the engine alongside the steam.
The vehicle will contain a mechanism for rolling the metal wire into a coil during the process of fuelling and the spent metal oxide, which was produced in the previous phase, will be collected from the car by vacuum suction.
