09-06-2008, 12:29 PM
#51
Originally Posted by Lurch
I believe it was around the year 1990 Galileo was finally pardoned for his criminal charges from when he made the silly claim that the earth revolved around the sun.
I don't remember that in the news.LOL
less lurking and more working
09-06-2008, 04:56 PM
#52
Water is not a fuel source. Fuels have energy in them to extract. Water is already burnt, it's burnt hydrogen. To 'prep' it, or unburn it and make it into a fuel again, you have to put in energy to split it. The amount of energy you put in will ***always*** be greater than what you get out by burning it again, even if only by a very small amount. It isn't a theory, it's a scientific law that's been proven time and time again through careful observation and experimentation.
09-06-2008, 05:14 PM
#53
not really sure how water is burnt, i think my sister has done it once or twice in an attempt to make dinner.
But if you wouldnt mind explaining i would gladly listen.
09-06-2008, 05:25 PM
#54
Water is already burnt, water is burnt hydrogen. You burn things by causing oxygen to attach, and water is H2O (Two hydrogenatoms attached to an oxygen atom). When you burn the hydrogen, the end result is simply water, oxidized hydrogen.
You can't run a car on water any more than you can run a car on ashes or smoke. The 'fuel' is already burnt, and it requires a great deal of energy to convert that water back into a usable fuel. Energy that had to come from somewhere, usually by burning fossil fuels.
We only do hydrogen injection on our cars to boost the engine's ability to convert gasoline into work. Requires only a small amount of hydrogen, nowhere near enough to fuel the engine by itself, but it doesn't take too much energy to make the small amount so the gain is worthwhile when tuned properly.
09-06-2008, 05:30 PM
#55
Okay, i have stumped several professors of some pretty good schools.
They dont understand how water is burnt. Infact they arent sure how water is created...... they know many ways in how it is created but not in as abundance as what we have on earth. and in all the ways they had listed i never once heard burnt.
09-06-2008, 05:31 PM
#56
alright, that was a good answer :P
09-06-2008, 05:35 PM
#57
So i will now rephrase my poorly worded post from earlier.
Hydrogen is a good fuel source and when in an oxygen rich environment has a much more volatile reaction to fire. both of the gases can be found in water, it just takes a little work to separate them.......
09-06-2008, 05:51 PM
#58
Now that's a good way to say it. Mind if I take that and run with it?
You can't run a car on water any more than you can fuel a wood stove with ashes.
Less, in fact, because ashes usually have tiny amounts of unburned wood still in them...
09-06-2008, 06:24 PM
#59
That's the problem, it takes alot of work to separate them, more work than you get back by burning it. It's an inefficient way to use energy. You'd be better off using that electricity to charge a battery and drive electric than to split water, compress the hydrogen, store it in a tank, pump it into a car, then burn it.
And please, please don't say you can use the alternator in the car to split enough water to run the engine... please. =\
09-06-2008, 06:48 PM
#60
but what if you happened to have hydrogen inside the ashes??
that would be remarkably similar to coal... actually, if i'm not mistaking that would be coal.
