Increase your HHO Output NOW!! - Fuelly Forums
Old 10-13-2008, 07:27 AM   #1
rgathright's Avatar
As you can see from the chart, disconnecting your alternator will save you gas mileage. Source: http://metrompg.com/posts/alternator-optional.htm
Why would you want to add a HHO device to your car that increases the amount of power needed from your alternator?
This HHO webpage even encourages you to add a bigger alternator and even add a secondary alternator!
http://www.hydrogenboostnow.com/200ampalt.html
I learn a lot about electronics and engines from sailing boats. Read this quote about the power required to spin an alternator:
The genset starts and runs at a preset throttle level providing 8-12 horsepower at around 2800-2900 rpms and consumes fuel (with slightly fluctuating rpm) based on the alternator loading. A 200 amp alternator requires a minimum 8HP motor, so the Kubota 482 is a good match. Because it is direct drive and there is no 3:1 pully driving the alternator up to 4500-6000 RPM (at 1500-2000 engine rpm) as with most engine alternators, the sustained amp output sits comfortably around 180 amps (200 when cold, 180 when hot). Fuel consumption is approximately 1 liter per hour at the 2800 rpm setting. That's enough on this for now, back to the installation...
Source: http://www.sailwhisper.com/logs/news_20080420.php
The man ordered an engine that would spin his 200Amp alternator on his sailboat.
rgathright is offline   Reply With Quote
Old 10-13-2008, 08:07 AM   #2
That's kinda funny!
The engine drives a 200 amp alternator and additionally has a smaller alternator belted to it.. haha
I've always wanted to get a generator like that and have it power an electric motor on the back tires.
- Kyle
Old 10-13-2008, 09:40 AM   #3
rgathright's Avatar
Originally Posted by dkjones96 View Post
That's kinda funny!
You could call your new product the DUH (Diesel Utility Hybrid).
Old 10-13-2008, 10:51 AM   #4
And for off-roading it's the DUR! (Diesel Utility Rover)
- Kyle
Old 10-15-2008, 02:52 AM   #5
ZugyNA's Avatar
In order to increase your mpg?
How to Increasing gas mileage on my 1993 Ford Ranger 4.0L automatic JIMTMCDANIELS General Fuel Topics 1 06-29-2008 04:36 PM
Help Me Explain this WorkingOnWise General Fuel Topics 9 06-09-2008 07:38 PM
