HHo heat...... - Fuelly Forums
Old 07-23-2013, 09:59 PM   #1
HHo heat......
HI. I'm a 'newbie' (10min. ago) and have a question about my wet cell heating up.
I just completed construction and installation of a 'Smacks Booster' and took it on a test run for 16 miles round trip. When I got back home, I popped the hood to check the booster and it was well over 200 degrees.
Can someone tell me why it's so hot?? This can't be normal. When I mixed the catalyst with the distilled water, I put two teaspoons of catalyst to one gal. of distilled water. The cell holds just under a half gal. of water.
Thanx,
sgtmike
sgtmike is offline   Reply With Quote
Old 07-24-2013, 04:55 AM   #2
I've never experimented with HHO myself, but from my understanding of how it works, varying the amount of catalyst will control the temperature.
Old 07-24-2013, 06:47 AM   #3
Thnx, Jay. I'll try a new mix and see if that helps.
Old 02-04-2014, 10:01 AM   #4
Thanx,
sgtmike
I hope you are talking degrees F.....
The purpose of the electrolyte is to improve the electrolysis of the system. This increases the conductivity of the water, thus drawing more current. More current always causes more heat.
Not sure what your current draw is, but my wet cell power supply used to draw 5 amps peak at 24vdc.....
I would suggest that there may be a little too much electrolyte in your mix.
Having said that, please take my advice under caution, as I do not use electrolyte addition to the water at all......
TheMadProfessor is offline   Reply With Quote
Looking for Eco-Driving Expert in Los Angeles iid research General Fuel Topics 3 06-21-2012 04:10 AM
new product to moniter your mpg/co2 emissions goofy1 General Discussion (Off-Topic) 6 07-09-2008 05:38 PM
Low power consumption cd player mji988 General Maintenance and Repair 10 06-27-2007 07:53 PM
Bought two new mowers and weed wacker psyshack General Discussion (Off-Topic) 5 05-21-2007 09:17 PM
Altima aerodynamics Compaq888 Aerodynamics 21 06-22-2006 09:57 AM
