HHO Generator Problem - Fuelly Forums
Old 04-27-2009, 07:59 PM   #1
I just installed an HHO generator, the Water4gas/mason jar type. Mine does not have a bubbler, ( Vacuum Adjustment Valve ). My problem is the engine idles too fast. When I disconnect the HHO generator and plug up the vacuum hose that goes from the HHO generator to the T connector, the engine idles fine.
I'm told I have a vacuum leak somewhere. IF I do, it only occurs with the HHO generator installed and running. The engine idles fine without it hooked up.
Since I do not have a bubbler to adjust the vacuum inside the HHO generator ( mason jar ), assuming it's air tight, there would be no vacuum leaks at this area.
My question: While the HHO generator is hooked up and running, I see all kinds of bubbling action inside the HHO generator.(Mason Jar) Shouldn't there be hardly any, if not, any at all? Since I have bubbling action, a lot, does that mean I do have a vacuum leak somewhere around the lid/seal of the jar, or somewhere?
Or, is it the opposite, meaning, with all the bubbles, does that mean I have too much vacuume inside the jar?
rodan99 is offline   Reply With Quote
Injector Cleaning. usedgeo General Maintenance and Repair 11 06-30-2008 06:43 PM
Help Me Explain this WorkingOnWise General Fuel Topics 9 06-09-2008 07:38 PM
