Help me with dry cell build - Fuelly Forums
Old 12-05-2016, 08:17 AM   #1
I am planning on building dry cell electrolyzer but when I looked around online I couldn't find any decent plans for one. I'm thinking my best bet would be to go with an 11 plate cell. I plan to use this for a hydroxy torch. I also have a small pump (75 GPH) that I want to use to circulate the water/electrolyte but I'm not sure if the electrolyte will rust/corrode the metal shaft over time. I also don't have anything to supply power other than a 12v 6 amp battery charger, but I don't think that would be enough.
Thanks in advanced.
ArcX is offline   Reply With Quote
Old 12-10-2016, 04:42 PM   #2
Thanks for all the help! I'll be sure to come here again.
I'll try to simplify what I was asking
1. I need some 11 plate HHO dry cell plans.
2. What power supply can I use to generate HHO.
Old 12-12-2016, 04:02 AM   #3
ArcX
It's unlikely that there is the expertise you require on Fuelly.
Most HHO generators have been debunked as snake oil.
You would be better of improving your driving techniques to improve your MPG's.
Just remember, if something sounds too good to be true it generally is.
But please, start logging your fuel usage here on Fuelly and if you get a HHO generator working and fitted to that car, we will all be able to see the improvements in your MPG.
Oliver.
OliverGT is offline   Reply With Quote
Old 12-14-2016, 06:13 PM   #4
Originally Posted by OliverGT View Post
ArcX
Oliver.
I don't plan on using it to boost MPG, I plan on using it for a hydroxy torch. do you know of any other forums that would have the knowledge to help me find some plans?
Thanks
Old 12-15-2016, 01:54 AM   #5
ArcX,
Apologies, I'm not able to help with other forums, I did a quick google and nothing really sprang out that would help, there are a couple of instrucatbles:
Hydroxy Gas Generator
Hydrogen Gas Torch
But I'm not sure if there is enough information for you on there.
Don't forget google is your friend, just be careful though. I tend to review the result set a little bit rather than just take the top of the list.
Tags
drycell, hho
