Ford MAP Enhancer Question - Fuelly Forums
Old 07-26-2008, 06:24 PM   #1
I have been told that a Ford MAP sensor sends its signal back to ECU in Hz rather than volts like the other manufactures. Has anyone used a MAP enhancer on a Ford MAP sensor? Will the MAP enhancer work on a Ford MAP sensor? If not what can I do to get around the MAP sensor when adding a HHO generator?
Hipermiler
#47 on my way to #1
Old 08-08-2008, 08:34 PM   #2
It is a 1988 Ford Escort 1.9L TBI. The reason for asking is that it has a frequency based sensor and I wasn't sure whether a MAP/MAF sensor enhancer would work correctly on it or not.
Hipermiler
#47 on my way to #1
Old 09-26-2009, 07:30 PM   #3
cabrera's Avatar
I'm sure by now you have your answer but for the sake of others who may ask, if you have a frequency based MAF/MAP a normal potentiometer MAF enhance won't work since it only regulates voltage.
Andy
cabrera is offline   Reply With Quote
hello Im new 90accord Introduce Yourself - New member Welcome 1 05-13-2008 11:04 PM
D15Z1 oxygen sensor and EGR pinout? StorminMatt General Fuel Topics 4 02-23-2008 03:34 AM
kumho kr21? FritzR General Fuel Topics 2 11-11-2007 05:38 PM
Wooly Tuft onegammyleg General Fuel Topics 1 09-11-2006 06:04 PM
Some wire tuck advice please? SVOboy General Maintenance and Repair 5 08-02-2006 06:30 PM
