Effect of Bad O Sensor? - Fuelly Forums
Old 07-20-2011, 10:01 AM   #1
Hi Forum,
What is the effect of a bad oxygen sensor? Does it make for a leaner, or richer fuel/air mix?
Thanks!
Mike
Cburg is offline   Reply With Quote
Old 07-20-2011, 03:18 PM   #2
GasSavers_Erik's Avatar
Re: Effect of Bad O Sensor?
The engine will run richer than it should as the oxygen sensor fails. The sensor will also respond more slowly to changes in the mixture.
When ECU recognizes that the sensor is not working properly, the check engine light will come on and the computer will ignore the oxygen sensor and use a programmed set of values that also cause the engine to run a little rich.
Old 07-20-2011, 10:25 PM   #3
Thanks Eric!
Mike
Add Groups? ScoutTech Fuelly Web Support and Community News 3 03-17-2010 10:35 PM
Need Help plz! HF tranny codes 78si General Fuel Topics 7 04-01-2009 09:12 PM
VX for sale in Toronto - $900!!! roadsterbum For Sale 8 07-25-2008 04:36 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
