Any truth to HHO - Page 2 - Fuelly Forums
Old 08-10-2008, 04:52 AM   #11
yea but my WOT throws me into open loop.
Don't you have a programmable computer? Can you program out open loop? If I understand correctly, the only reason WOT closed loop requires a wideband O2 is if it's expected to make maximum power, and you could just program it out and lose a couple HP at top end...
Old 08-10-2008, 06:10 AM   #12
If the TPS is the only way the ECU knows you're at full throttle, then hacking that with a resistor in the right place might work... unless the ECU figures it out and faults it.
Old 08-10-2008, 02:51 PM   #13
Originally Posted by mrjetskey View Post
I was wondering if the HHO produced at say 5LPM of it would actually oxidize the gasoline it was mixed with in the combustion chamber sort of like NOX does?
HHO (more commonly known as H2O, or water) is very stable, already oxidized. HHO will not oxidize hydrocarbons. If you are referring to H2, H2 cannot oxidize anything, it is a powerful reducing agent......not an oxidizing agent. Basic chemistry. High School stuff.
Old 08-11-2008, 06:25 AM   #14
thornburg's Avatar
If you know so much about basic chemistry, you should know that HHO is NOT the same thing as H2O. HHO is Brown's Gas. It has very different properties than water (despite having the same base elements in the same ratio).
You can run a welding torch on Brown's Gas. Can you run a welding torch on water vapor or steam?
Old 08-27-2008, 11:16 AM   #15
hod
The Canadian Hydrogen Energy Company guarantees a minimum of 10-percent improvement for diesel trucks using their hydrogen fuel injection technology, (which is really HHO gas). Results are likely more since this is a minimum.
hydrogen on demand
hod is offline   Reply With Quote
new epa or old epa in the garage?> thisisntjared General Discussion (Off-Topic) 7 05-22-2008 08:09 PM
A shot with a mix... GasSavers_SD26 Diesels 23 03-13-2008 06:20 PM
Air scoop for mpg? ZugyNA Experiments, Modifications and DIY 10 12-05-2007 10:40 AM
BIG car Andy-Paul Transmissions and Running Gear 30 10-24-2007 02:25 PM
