07-12-2010, 05:09 AM
Thoughts on switching to Midgrade fuel?
Harley recommends 91 octane fuel, but since I'm not running the bike hard (I'm very rarely using more than 25% throttle), and it is computer controlled fuel injection, what are everyone's thoughts on me switching to 89 octane fuel? Saving $0.15/gal would be nice.
07-12-2010, 07:22 AM
try it, and listen for pinging. if it pings, go back to premium. I run regular in my valkyrie with no problems.
07-12-2010, 07:34 AM
Thanks. Do you know if the computer controls on motorcycles work like they do on cars? I'm pretty sure a car would retard the timing, I'm not sure about the bike though.
07-12-2010, 08:38 AM
Site Team
If there are knock detectors on motorcycles, I would think they would have to be a lot smaller than the automotive versions...
-BC
07-12-2010, 11:27 AM
My Honda CBF has got a lot of sensors (throttle position, MAPsensor, coolanttemp, airtemp, lambdasensor, bank angle sensor, rpm...) but I've never seen a motorcycle with a knocksensor.
My opinion: don't change to lower octane rate as manufacturers recommandation. You'll see that on that hot day, with a hot engine you need some power (think about your safety) and your engine will not deliver as designed and there's a risk on engine damage.
I would only risk it with a knocksensor, but even then your engine might not perform as expected.
07-12-2010, 05:01 PM
How many gallon tank do you have? Maybe a five gallon tank? Typically there's a 20 cent/gallon difference between regular and premium. If you pushed the bike into the gas station,
you might save a buck. At 40 mpg, that would be a savings of $50 in 10k miles. Not much, when you think about it.
OTOH, you could try a tank and see what happens...it might work ok.
07-12-2010, 06:36 PM
In my area there's generally a $0.30 - $0.45/gal difference between 87 and 93 octane. You are right though, it is only a 5 gallon tank, and I haven't let it get under 1/2 tank so far.
I think I can do a good compromise. Since 91 is recommended, and stations in my area carry 87, 89, and 93, and I've been filling up at around 1/2 tank if I alternate between 89 and 93 then I'll end up with 91 in the tank.
07-12-2010, 09:07 PM
Here, the only station I've seen with 93 octane gets $6.99/gallon for it.
07-13-2010, 03:05 AM
In this area the Premium is 93, and one brand has 95. I think its Exxon that's 95 octane. I never really looked at Premium before now.
07-13-2010, 12:58 PM
motorcycle manufacturers have to factor in all types of people riding in all types of conditions. big people, small people, riding with a passenger, outside temperature changes,altitude, etc. If you are not riding hard, and no passenger, mainly commuting to work, I would try a lower octane fuel. If it pings, drop a gear, and let off the throttle,it's not rocket science.
