'Nother electric Motorcycle - Fuelly Forums
Old 02-05-2009, 09:55 AM   #1
cat0020's Avatar
Question 'Nother electric Motorcycle
Not a whole lot of "utility" for the vehicle's design principals.. maybe performance could be reduced for more underseat/lockable storage?
Target Performance
Top Speed: 150mph
Range: 150 miles per charge (est. EPA drive cycle)
Recharge Time: Under 2 Hours @ 240V (8 Hours @ 120V)
Interactive Feature: Adjustable regenerative rear wheel braking
Interactive Feature: Intuitive / adjustable data acquisition system
Old 02-05-2009, 09:57 AM   #2
After 150 miles your back would be killing you anyways!
It's weird. I like it.
- Kyle
Old 02-05-2009, 10:05 AM   #3
Originally Posted by cat0020 View Post
Target Performance
I'd have thought that a target set 25% beyond current (pun) range would be enough, but to triple the reasonable expectations? WOW!
Way to set one's self up for assured 'failure'.
Even at 100 mile range, double almost any other fully electric road vehicle, the result will be failing to reach the insane goal.
Old 02-05-2009, 11:36 AM   #4
Looking at it again...
Motors are to motorcycles like cleavage is to women.
This bike doesn't have enough cleavage!
- Kyle
Old 02-06-2009, 05:56 AM   #5
cat0020's Avatar
I see the purpose of a electric moto being conserving fossil fuel with less impact on environment, sport bikes in general are not particualrly good at neither. I guess I don't understand the reason for designing/creating another "sport" bike with electric motor, the uncomfortable riding position would deter the masses from purchasing. If the performance of the electric motor could be combined with some decent riding comfot, a la scooter style, maybe more people would be into "sport" bikes, or sport type riding.
Old 02-06-2009, 06:00 AM   #6
Fit that system into a Burgman!
- Kyle
Old 02-06-2009, 07:33 AM   #7
GasSavers_BEEF's Avatar
if you could put it on a scooter and it would do 70mph (or at least 60)
I think the market would be pretty big for it, even bigger if you could put it in a 3 wheeler for stability.
still keeping the range at over 50 miles, I would consider one.
Old 02-06-2009, 09:35 AM   #8
Something not quite right there . . . first that is a lot of speed for something that small, second there does not seem to be enough space for batteries in that frame to be able to go that many miles, third why is there a hydralic lever on the left AND right sides unless there is a transmission that requires a clutch.
Old 02-06-2009, 09:54 AM   #9
It shouldn't be hard or expensive to convert an existing gas scooter to run alright on batteries, you might lose cargo space but it can't be that bad.
Your typical 150cc scooter makes around 10 horsepower and 8.5hp golf cart motors can be had for under $400 for the most part. You could run that motor direct drive and get rid of that power robbing CVT. Just make sure it's geared well enough to get you up to 55 at the motor's peak hp rpm and give the controller the ability to over-run the motor by a couple hundred rpm for a short time.
- Kyle
Old 02-06-2009, 10:16 AM   #10
GasSavers_Colin's Avatar
Send a message via AIM to GasSavers_Colin
Originally Posted by JanGeo View Post
Something not quite right there . . . why is there a hydralic lever on the left AND right sides unless there is a transmission that requires a clutch.
I don't see a foot lever for the rear brake - maybe it has a left-hand rear brake, like a scooter.
Colin Doyle
limefrog@mac.com
GasSavers_Colin is offline   Reply With Quote
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 07:41 AM
Air Dam and Bellypan Material GasSavers_rayjay Aerodynamics 22 06-13-2008 11:38 PM
PepsiCo Connections? SVOboy General Discussion (Off-Topic) 3 10-12-2006 05:52 PM
