07-31-2009, 08:48 AM
Originally Posted by mikehallbackhoe
I have tried eoc on my valk on steep downhill runs, but found it difficult to hold in the clutch very long ( carpal tunnel) don't think it was worth the effort
That is where you just cut the engine and cruise....right?
I don't like that, because it increases clutch wear. Here is an example of what would sometimes happen. The clutch could be fully released, yes, the engint woudn't turn over (this was on my 250). The proper technique was to press the start button slightly before releasing the clutch. You didn't have to start the engine with the start button, just get it spinning.
The problem is many bike clutches, (friction discs, pressure plates, etc.) are continually optimized, through grooves, etc. for optimal holding power when transfering power to the road, not the opposite. They infact re- design the whold clutch to do just that with slipper clutches. If your bike has the starter relay/solenoid dependent on the clutch being pulled in, I would simply press the button while holding the clutch lever in and release int quicly, but in a controlled manner. A little practice and you can get it just right.
This helped me get a max of almost 70 miles per gallon on the ninja 250 with a tiny bit of city driving. Some ninja 250 riders get 88, but, they undoubtably probably have sprockets and windscreens.
Oh you know another thing I just thought of aswell....Some trunks, if they're positioned properly can increase gas mileage, verses saddle bags that stick out to the side. Position them in the slip stream!
07-31-2009, 09:06 AM
EOC (Engine Off Coasting) is when you coast with the engine turned off, in neutral or holding the clutch disengaged. As I mentioned before, my gut feeling is that it's a bad idea on motorcycles.
