05-20-2009, 05:00 AM
#21
Contact patch size probably depends mainly on pressure, not tire size. Contact patch shape is what changes when you change tire size. If there's 450 pounds on a tire with 45psi (pounds per square inch), it's going to have 10 square inches of contact patch. On a ten inch wide tire, that's a 1 inch long contact patch. On a 5 inch wide tire, it would be 2 inches long. On a 2 inch wide tire it would be 5 inches long.
Assuming the same pressure and a significantly larger tire, rolling resistance is reduced significantly. Oversizing while keeping the same inflation is effectively overinflating.
05-20-2009, 05:25 AM
#22
my valkyrie holds 5.3 gallons, but 1.14 gallons is reserve.I fill up as soon as possible when I hit reserve, I switch to reserve between 180 and 200 miles , usually takes 4 gallons to top off. mpg drops a couple of miles when carrying a passenger. I came to this site to get some info, I am grateful for that info by the way, but I am tired of having to defend my mods and my ride, and having my honesty questioned, so I am out of here.
05-20-2009, 05:29 AM
#23
By pressure, do you mean the weight that the tire carries?
2-up on a 700+ lb. moto with 205 60 16 car tire vs 180 70 16 standard Valkyrie rear tire.. which do you think might have larger contact patch?
05-20-2009, 05:35 AM
#24
I'm sorry you feel that way, there are many here hypermiling with non-conventional vehicles not known for mileage. For example, my primary vehicle is a V-8 4x4 pickup truck that I can get the EPA highway rating driving in city traffic. Holy Cow also has a 4wd pickup that he hypermiles with as well. Phillip hypermiles with a stationwagon. This is a great site for information on hypermiling with vehicles that people don't usually hypermile. Other sites generally have the attitude that if you're not hypermiling a Prius or a Geo Metro then you're wasting their time.
05-20-2009, 05:44 AM
#25
No. "Pressure" in a tire discussion is always about tire inflation pressure, the pressure of the air inside the tire. That's why I was talking about overinflation and such.
Tell me the weight on the tire and the pressure in the tire, I'll tell you the contact patch. I don't need to know the tire size.
Let's say 400 pounds of those 700 are on the tire, and there's 30psi in it...there would be a 13.3 square inch contact patch. The 205-60-16 is 8 inches wide so the contact patch will be 8 inches wide by 1.66 inches long. The 180-70-16 tire is 7 inches wide so the contact patch will be 7 inches wide by 1.9 inches long.
I assume that a motorcycle tire is generally rounder in profile than the square-shaped profile of a car tire, which would mean that the motorcycle tire may not effectively be as wide; I'd guess that the width measurement is at the sidewall, not where the tread meets the road. The motorcycle tire will have to do a lot more flexing and deforming to make that contact patch, which would increase rolling resistance. OTOH, the motorcycle tire is probably a fraction of the thickness of the car tire, so that would probably reduce rolling resistance.
05-20-2009, 05:55 AM
#26
My estimate: Valkyrie 700-720 lb., rider 200-220 lb., passenger 160-180 lb., total approx. 1060-1120 lb. 36 psi in tire. What's the contact patch size?
05-20-2009, 06:12 AM
#27
All that weight is on one tire? I would expect the front tire to carry some of the weight too.
1060-1120lb at 36psi is 30-31 square inches.
05-20-2009, 10:53 AM
#28
You didn't specify the front and rear weight ratio..
Contact patch is 30-31 square inches for all sizes of tires?
05-20-2009, 11:16 AM
#29
I asked how much weight was on the tire, not how much weight was on both tires.
Given the weight (on that single tire) and the inflation pressures I worked with, yes. The math is pretty simple. You have pounds, and you have PSI (Pounds per Square Inch). Divide out the pounds and you're left with square inches.
05-20-2009, 11:39 AM
#30
Different tire rubber/silica/material compound does not effect the contact patch size?
