mods for better mpg - Fuelly Forums
Old 05-20-2009, 05:29 AM   #11
cat0020's Avatar
Question
Contact patch size probably depends mainly on pressure, not tire size. Contact patch shape is what changes when you change tire size. If there's 450 pounds on a tire with 45psi (pounds per square inch), it's going to have 10 square inches of contact patch. On a ten inch wide tire, that's a 1 inch long contact patch. On a 5 inch wide tire, it would be 2 inches long. On a 2 inch wide tire it would be 5 inches long.
Assuming the same pressure and a significantly larger tire, rolling resistance is reduced significantly. Oversizing while keeping the same inflation is effectively overinflating.
By pressure, do you mean the weight that the tire carries?
2-up on a 700+ lb. moto with 205 60 16 car tire vs 180 70 16 standard Valkyrie rear tire.. which do you think might have larger contact patch?
Trade? 1999 Subaru Legacy Wagon AWD, Automatic for Gassaver Car GasSavers_silvergt For Sale 0 12-30-2007 07:45 PM
Congratulations Jared!!! SVOboy General Discussion (Off-Topic) 7 08-13-2006 08:55 PM
hello GasSavers_nathan Introduce Yourself - New member Welcome 3 12-07-2005 03:59 PM
