How to better the MPG's on my '75 175cc enduro - Fuelly Forums
Old 02-02-2010, 03:14 PM   #1
I currently can go about 50 miles per tank and I have a 1.8 Gallon tank. I get like 27 or so. I dont know what to do. Its a 175cc Carborated 2 stroke. I do ride it incredibly hard, but still...
I also want to keep it fairly easy to switch back to normal, or even riding styles. I mean, Its a classic and VERY low milage so I would like to keep it stock if possible
Going GTO once I finally get a job. Stayin pontiac all the way.
NotYourDay is offline   Reply With Quote
Old 02-02-2010, 06:41 PM   #2
Have you considered going to a larger front sprocket and smaller sprocket on the rear to give it taller gearing.
Hipermiler
#47 on my way to #1
Old 02-02-2010, 08:57 PM   #3
DRW
That's a tough question! An old Enduro 175 doesn't have much power, so taller gearing would be a compromise. Maybe try 2 teeth smaller on the rear spocket and see how it feels.
If it has an adjustable needle in the carb, try lowering the needle/raising the C-clip one notch. That should lean it out a little in the midrange. The needle is easy to change in most old carbs.
Dave W.
Old 02-03-2010, 08:46 AM   #4
cat0020's Avatar
How much weight can you loose?
Old 02-03-2010, 07:59 PM   #5
DRW
Get into an aerodynamic tuck whenever you ride it.
Dave W.
Old 02-04-2010, 01:34 PM   #6
Two stroke motors were gas pigs until recently. The exhaust scavenging process blows about 1/3 of the fuel from the carburetor right out through the exhaust. Either get a 4-stroke, or wait intil direct fuel injection becomes available.
air wings for motorcycle mikehallbackhoe Aerodynamics 0 05-15-2009 09:46 AM
