09-15-2014, 11:09 AM
Ethanol Treatment
date line 2011, i notice i'm was getting less mpg using ethanol blend fuel in my 05 suzuki v-strom 1000. (avg. -1.5 mpg) then, i heard that ethanol treatment fuel additive would fix the problem. so i gave it a try. wow, it works. using sta-bil marine formula ethanol treatment, i got back the lose mpg. now getting same mpg as before ethanol blend fuel. i been using the stuff continuously ever since.
03-05-2015, 10:15 PM
At what mix ratio are you using sta-bil in your Suzuki?
I am considering cat-delete and ashless 2 cycle oil in my air cooled fuel injected 125cc mini-bike
Grom Honda at lawn-boy mower mix ratio or less oil.
This worked in an old Briggs&Stratton grass cutter...which only stalled every 3 feet on 87 octane and cut like a champ on lawn boy gas and oil mix..
03-11-2015, 06:56 PM
1oz. treatment per 1us gal. fuel..
03-11-2015, 08:15 PM
Thank you. I have found this sta-bil marine ethanol formula at a local store.
03-12-2015, 06:06 PM
sorry, i meant to say 1/2 oz. per 5 us gals..
03-12-2015, 11:45 PM
wow ! that little bit makes a difference ??
The 2-cycle smokeless G-oil synthetic formula at 87:1 or 60:1 has no noticeable effect on fuel economy...but did increase torque and the little 125cc engine runs smoother.
09-22-2015, 09:06 AM
Do you use it w/ every fill-up, or every other fill-up?
10-19-2015, 07:33 AM
i use ethanol treatment at every fill-up whenever possible.
