2nd Fill Up - Fuelly Forums
Old 05-25-2007, 08:09 AM   #1
2nd Fill Up
Well I updated my gas log on the Ninja 250. I squeeked out 76mpg this time. This is a real fun bike to ride around on.
korax123 is offline   Reply With Quote
Old 05-25-2007, 08:12 AM   #2
jwxr7's Avatar
Yeah, my brother had one of those. Those engines like the high rpms .
Old 05-25-2007, 12:15 PM   #3
zpiloto's Avatar
Nice. How hard were you trying this time around and have you done anything to it (FE wise)? Hey you need to move it into the motocycle top ten list.
Old 05-25-2007, 12:38 PM   #4
I don't really try that hard with the bike. I did go WOT about 3 times this time around. The bike is definatly fast enough to get out of the way. I need to get a new sprocket to lower the cruising RPM's. I can porb get about 80mpg then. But im still new to motorcycle's so I am going to leave it alone for now.
Old 05-25-2007, 10:51 PM   #5
Hockey4mnhs's Avatar
niiiiiice
Old 05-25-2007, 10:58 PM   #6
hey i want to see some pics of this thing so i know what to look for on the streets
Old 05-27-2007, 10:00 PM   #7
GasSavers_Ryland's Avatar
there are devices avalible, mostly for dirt bikes, but it's a vane of sorts that fits in the opening of the carburator, so that at a quarter or half throttle opening, it's not just the throttle slide that is creating that sized opening, but this vane blocking off the rest of the unused part of the opening next to the throttle slide to help keep the air velosity higher, apparently giving better low end torque, it's a simaler idea as a multi barrle carburator, altho I can't remember what this product is call, nor can I find something like it on the internet.
I've also read about what basicly is a computer muffen fan in your air box to keep the air presure higher, only the fan doesn't have a motor, it just spins from the air entering, of course as the air enters in pulses the fan helps to build presure between pulses, but I wonder what would happen if you just installed a small fan and ran it off the battery, low presure electric super charger kind of thing.
Old 05-28-2007, 06:16 AM   #8
GasSavers_bobski's Avatar
While user pics are always cool, it is listed on the Kawasaki website.
Old 05-29-2007, 11:31 AM   #9
jwxr7's Avatar
If you goto your garage and select "edit", under "type", select motorcycle instead of gasoline .
Old 06-01-2007, 08:47 AM   #10
These motorless fans have been independently tested to give absolutely no benefit in a motorcycle. They are also quite expensive if I remember correctly (somewhere around $100).
Even a relatively small motorcycle engine like the 250 Ninja in the post uses way more air than could be supplied by a small fan. Basically you would be just adding restriction to the intake which breeds inefficiency.
But perhaps from a mileage standpoint restriction would equal greater fuel mileage?
An interesting factoid, some members of my motorcycle forum have found that by putting in high compression pistons (of course for greater performance) their mileage has significantly increased. I imagine this is due to more efficient combustion.
BisbeeWarrior is offline   Reply With Quote
Rolling Averages? dunderhi Fuelly Web Support and Community News 7 08-17-2015 11:42 AM
Batch Import? somedirection Fuelly Web Support and Community News 5 08-08-2008 08:25 AM
Source of Vinyl sheeting. CoyoteX General Maintenance and Repair 4 12-17-2006 12:08 PM
Bike car video kickflipjr People Powered 7 12-16-2006 10:02 PM
Scanguage II Calibration: 'Adjustment Factor on Fillup' smartzuuk General Fuel Topics 28 12-01-2006 03:39 AM
