Smart Car review - input requested! - Page 2 - Fuelly Forums
Go Back   Fuelly Forums > News and Articles > Car Reviews
Old 10-21-2014, 01:25 PM   #11
....and although I never lived in Virginia (I've lived in NC) I don't think it gets as cold as here in the winter. In fact, I'd place a large wager on it
LouSiffer is offline   Reply With Quote
Old 10-21-2014, 05:16 PM   #12
Originally Posted by trollbait View Post
Were any of those diesels under a liter, Jay?
No, they were huge diesels... 7-8 liters.
Old 10-21-2014, 05:18 PM   #13
I was just speaking comparatively, the diesels I've driven would start blowing heat within a minute or 2, my V8 pickup truck won't blow heat for about 10 minutes. The only exception I've seen is my Escape Hybrid. That will start blowing heat in about 30 seconds.
Old 10-22-2014, 06:34 AM   #14
My friend's 1980 diesel Rabbit would leak heat from the floor vents all the time. Even though a diesel can burn less fuel, the higher compression ratio might aid in creating heat. So they could generate heat faster than a gasoline engine, when driven. TDIClub claims that the amount of fuel burned at idle will take forever to heat the engine to the point of heating the cabin.
Tiny engines, like the 0.8L in a smart diesel, have a higher surface area than larger engines. That with the smaller mass mean the engine will radiate heat faster than the big ones. The faster air cooling means the coolant takes longer to heat up.
Many hybrids use supplemental electric heaters to make up for the ICE running less to generate heat.
Old 10-23-2014, 06:10 AM   #15
The basic problem is that internal combustion engined cars use waste engine heat to warm the cabin. As the engine becomes more efficient there is less waste heat. At idle, diesels still run full charges of outside cold air through themselves, and that cold air also cools the engine. Yes, the air is heated by compression, but it cools again during the ensuing expansion cycle. In the end, the only place the heat comes from is the burning of fuel. You don't burn much fuel, you don't get much heat. You want the engine to warm quickly, you start it, wait a short time (less than a minute) for the oil pressure to come up, then drive off. If circumstances permit, stand on the accelerator to get the turbo to spool up. If you worry about potential damage to the engine, examine the way in which a standby generator starts when the power fails.
Charon is offline   Reply With Quote
GasSavers.org Stickers 70DIMER For Sale 20 09-22-2010 04:46 PM
G'day from Australia. GasSavers_Pete Introduce Yourself - New member Welcome 5 01-01-2008 06:44 PM
New Member smccall Introduce Yourself - New member Welcome 18 10-01-2007 11:48 AM
Condensator orevgym General Fuel Topics 0 07-23-2006 11:25 AM
