Turned in the Monte this Morning...
2007 Monte Carlo LT, 3.5L Flex-Fuel
+ Handling
+ Decent FE for Size
+ Steering Wheel Controls
- Numb Steering Feedback
- Impala/Monte "Clunk" in the steering column
- Terrible seating position
You can tell they started with the Impala, and just kinda went from there with the Monte Carlo. But, good reason I suppose. The "Personal, Full-Size Coupe" segment is dwindling. The sucess of Cutlass Supreme of the late 70's peaked this segment style, and it's gone downhill since.
The Interior was much like the Impala with similar components, except for the dash -- which had oddly placed vents. The seat didn't seem to fit the car -- despite it's 6-way action with lumbar support, it just sat too high. Extras included heated leather seats and handy steering wheel buttons for the radio.
The drive: the chassis and suspension seemed to be stiffened for the coupe. It handled well, but the steering couldn't tell you much of what was going on. The Chevy essentially idled down the highway at very low RPMs, which provided good FE. 1st gear actually redline at 55 mph!
E85 Experience (
check out this thread regarding Ethanol):
The final result of E85:
21.6 MPG (27.5% drop -- additional city driving included, but overall the same was noticed at highway cruise)
258 miles
52.0 mph
11.94 gallons
Power seemed to increase, and it took the vehicle some time to fully adjust (rough cold starts with idle-skip).
Look for this to be a TSB for these cars. Every Impala or Monte that I've driven from 2007 has an annoying "Clunk" in the steering column. It happens on light road bumps or giving the engine some throttle. It's like two metal pieces are striking together in the steering column -- could be in the suspension or elsewhere
The model that did it the most was the Active Fuel Management model -- when it changed from 6 to 3 Cylinders (or back), the clunk was very noticable.
It was fun to drive, and reminded me a bit of High School when I had my V-6 Beretta -- but the 4-door version can be bought with the same engine and options, which is recommended (see Impala write-up).
In conclusion, the car was rented primarily to test the E85, which worked as expected, but with a larger hit in FE that predicted -- a drop of 27.5%. I attribute this to the ECU probably having never been introduced to E85, and safely compensating.
(pics to follow)
