WTB: honda HF Transmission - Fuelly Forums
Go Back   Fuelly Forums > Marketplace | Buy, Sell, Trade > Wanted to Buy
Old 10-23-2007, 12:46 PM   #1
Member
78si's Avatar
Low miles and clean if possible. Thanks
78si is offline   Reply With Quote
Old 10-23-2007, 04:32 PM   #2
If your looking for an HF transmission, it would be a good idea to give some additional information. 84-87 was one design. 88-91 is a completely different design. 88 is not 100% compatible with 89-91, but it's primary difference is the spline count on the main shaft is different, so you have to use a clutch and pressure plate for an 88.
Then their is the question of if you are looking for a CA version, Fed version, or High Altitude version. The CA version isn't geared quite as long as the Fed version, although it's still geared longer than a DX. I'm not quite sure what the difference is on between a Fed version and the High Altitude version.
Old 10-23-2007, 06:21 PM   #3
Member
78si's Avatar
Anything will be better than what have. I can change out the clutch and flywheel to match the tranny splines.
Old 10-23-2007, 06:38 PM   #4
Can't you get something through your importer friend or can he not get US stuff?
Old 10-28-2007, 12:51 PM   #5
Member
78si's Avatar
He imports from Japan.. The jdm stuff usually has short geared trannys. I have only seen one HF crx in my life!
Old 10-29-2007, 10:37 AM   #6
Did they even have an HF version in Japan?
McPatrick is offline   Reply With Quote
Old 10-29-2007, 10:20 PM   #7
Member
78si's Avatar
I'm not sure if japan had HF's. Does anyone know the HF tranny code? ..Or do I have to rotate the input shaft to calculate the gearing..
Old 10-30-2007, 11:32 AM   #8
http://sfbay.craigslist.org/sfc/pts/463682608.html
Old 10-30-2007, 01:18 PM   #9
GasSavers_Ryland's Avatar
I did a search on car-part.com, and found:
1986
Transmission
Honda CRX 6-86,FWD,1500,MT,FL, HF 90,000 A 865086 $Call D & E Auto Parts, Inc. RP+ Member USA-WI(Elkhorn) E-mail 1-262-742-2220
but that is just what is closest to me, but 90,000 miles isn't bad.
Old 10-30-2007, 10:24 PM   #10
Member
78si's Avatar
Thanks.
Please Add Time of Day to Fuel Up Screen xoraclez Fuelly Web Support and Community News 1 03-29-2013 08:03 AM
VX Head Question GasSavers_scostanz General Maintenance and Repair 8 02-17-2007 04:27 AM
What are your shifting patterns??? Compaq888 Hypermiling 13 08-22-2006 07:41 PM
thought this article was interesting bagpipe goatee General Fuel Topics 1 09-06-2005 10:57 AM
