WTB: 88-91 civic a/c system - Fuelly Forums
Go Back   Fuelly Forums > Marketplace | Buy, Sell, Trade > Wanted to Buy
Old 01-10-2007, 01:42 AM   #1
I am looking to put a/c into my 91 civic std, so anybody who doesn't use it, gimme, gimme, gimme.
I won't be able to use this car for work unless it has a/c
This would only work if there were anybody within 100 miles of nj, cause it ain't worth shipping.
I need:
compressor
condensor
fan
lines
brackets/bolts
wiring harness (under hood)
a/c relay (in engine bay fuse box)
underdash evaporator box
belt/tensioner
button
budomove is offline   Reply With Quote
Old 01-10-2007, 05:31 AM   #2
Moderator
GasSavers_DaX's Avatar
Was AC not an option that came on your STD or did you just remove it? If you have one of the STD's that came without AC, you can probably sell the button block off and the evap box bypass tube under the dash to someone who wants to remove ALL AC components but retain the heater function.
Local junkyard may be your best bet...I had to replace my evaporator last year...got a new/old one for $20 from Pull-A-Part.
Old 01-10-2007, 10:17 AM   #3
Budomove: I need to put an A/C system into my 89 Honda. I was able to wait for a 50% off sale at Pick A Part, then I went down and found an similar model car, with a little pressure still in the A/C. I pulled all of the parts for the A/C off, and I probably spent about $100.
I also did the same thing for an 87 Hatchback, which one of my daughter's is driving while she goes to College. That one I finished installing in late June, got it evactuated and recharged, and it was much more pleasant with the A/C, in the summer time, than not.
Good Luck!
Old 01-10-2007, 11:18 AM   #4
Yeah, I'd love to find a car to pluck the a/c from, it'd be a good way of familiarizing myself with the system b4 installing it on my car.
Thanks for your help guys, I will continue looking for a vehicle.
Old 01-10-2007, 10:59 PM   #5
GasSavers_Diemaster's Avatar
i have the part that bolts to the block; that the compressor bolts to. it also has the tentoner.
how much u willing for it. i'm flexable.
I ♥ my EM2
Need this stuff gone!
https://www.honda-tech.com/zero...67053[/B]
GasSavers_Diemaster is offline   Reply With Quote
Old 12-20-2010, 12:04 PM   #6
Re: WTB: 88-91 civic a/c system
I Just pulled my AC system out yesterday.. Its is in perfect working condition. Just install and ad freon. Everything you need hoses mounts and everything.
Johnydondo@gmail.com If interested.
Johnydondo is offline   Reply With Quote
Jetta Hybrid bates General Fuel Topics 13 10-17-2013 06:15 AM
Fuel-up Log View absi Fuelly Web Support and Community News 5 06-24-2011 03:01 PM
Car stalls when idling and A/C is on Matt Timion General Maintenance and Repair 7 05-20-2006 04:32 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 01:52 AM
DIY: Custom Shift Knob Coloring SVOboy Experiments, Modifications and DIY 5 01-12-2006 05:55 AM
