96-98 civic hx mt engine wiring harness - Fuelly Forums
Go Back   Fuelly Forums > Marketplace | Buy, Sell, Trade > Wanted to Buy
Old 03-07-2007, 07:06 PM   #1
i am swapping a 97 civic hx engine into my 89 crx hf. I am going to keep this engine obd2. I have all the parts i need except the 8 pin connector that mates up with 8 pin wide band oxygen sensor used on the D16y5 engine. It must be a civic hx with a manual tranny. if you have a wiring harness (damaged cut or complete) it doesn't matter as long as this 8 pin connector is good). I hope some one has cut off this connector because they swapped out a d16y5 and didn't need to continue to use this sensor. If you know of one please help me out. I can straight wire the sensor but i would rather do it right. thanks johnmccarson@charter.net
pappajohn is offline   Reply With Quote
Old 03-08-2007, 05:44 PM   #2
|V3|2D
thisisntjared's Avatar
changing an obd0 car to obd2 is not a good idea.... MAYBE and i mean maybe if you have underdash wiring harness and the engine bay harness...or you LOVE running wires. good luck.
Old 03-09-2007, 08:47 AM   #3
Wink
It don't look to bad i'm useing the stock ecu and wiring harness and all i must wire up is the signals that is not part of the engine and several 12v and grounds . The only reason i need the connector is the engine was an automatic. It used a 4 wire o2 sensor.
Speed sensor, fuel system vacuum and clutch is the only signals that are not part of the wiring harness {that i can remember). Then battery and ground! thanks for the advice though Jared.
Old 03-09-2007, 09:42 PM   #4
|V3|2D
so i take it you love wires
Old 03-10-2007, 05:17 AM   #5
Tuggin at the surly bonds
Silveredwings's Avatar
It's the current thing to do.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 08:48 AM
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 10:10 PM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 01:52 AM
Sharing Indexing Washers SVOboy General Fuel Topics 0 04-01-2006 02:36 PM
