'94 civic DX coupe - Page 3 - Fuelly Forums
Go Back   Fuelly Forums > Marketplace | Buy, Sell, Trade > Wanted to Buy
Old 09-28-2007, 07:30 AM   #21
GasSavers_TomO's Avatar
If you have a family friend that can weld nicely, then go for it. I can't see the subframe in the pictures, maybe you can get some shots from under the rear of the car?
Honda Civic VX Info/Links
Old 09-28-2007, 03:23 PM   #22
will try to get pictures up tomorrow.
should i jack up the back of the car and take a shot from underneath?
the back of the car is fine, just that side between the wheels, but it looks to me like it's eroding the frame.
you can see in the 2nd picture the place where the jack is meant to go. that huge hole came from trying to jack the car up and it just completely fell through on itself.
so if that area is supposed to be strong enough to support the weight of the car, it's not!
wombosi is offline   Reply With Quote
Old 09-29-2007, 06:46 PM   #23
|V3|2D
thisisntjared's Avatar
dont ride with passengers in the back and your car is now safer hahaha you just got another crumple zone for a rear collision!
Old 09-29-2007, 07:19 PM   #24
Jack up the back of the car from the tow point in the middle and snap some pictures and close ups of where the lower control arms attach to the frame.
The real backbone of the Civic unibody is from the rear subframe up to the front lower crossmember. As long as that is all together, then you're fine.
Old 09-30-2007, 11:17 AM   #25
new pics
Hi TomO.
I've taken some pics. I hope they're helpful in your judgement.
I fear the car is more or less a goner...
Old 09-30-2007, 12:38 PM   #26
Originally Posted by wombosi View Post
Hi TomO.
The rear subframe looks to be intact with no signs of rusting....so you can drive the car into the ground at this point.
As far as making it look better to pass inspection...first use a rust converter to slow down the rust, then I'd use a can of expanding foam from Home Depot or the like and fill in the hole, shape the foam once it's cured and then body filler or fiberglass over it and paint it to match.
Old 09-30-2007, 12:43 PM   #27
thanks man. good idea.
what is a rust converter?
thanks again.
Old 10-14-2007, 09:32 PM   #28
Danronian's Avatar
thanks again.
It's like a primer used for rusty metal that slows down the rusting process. You can buy it at most parts stores near the primer and car paint/prep products.
I agree on driving it into the ground.
Just bondo it up. Undercoat/seal that area of the car so hopefully your Bondo work stays pretty well together for a while. And drive drive drive.
Update the Model List? Logan Fuelly Web Support and Community News 6 09-23-2009 04:18 AM
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 04:13 AM
Just got my '95 VX whychug Introduce Yourself - New member Welcome 7 01-30-2007 07:24 AM
Short trips takes its toll on FE onegammyleg General Discussion (Off-Topic) 9 10-24-2006 11:36 PM
5 different Metros for Sale-Perkasie, Pa / cams XFi For Sale 11 08-26-2006 05:17 AM
