obddiagnostics.com ??? - Fuelly Forums
Go Back   Fuelly Forums > Marketplace | Buy, Sell, Trade > For Sale
Closed Thread
Old 12-15-2006, 11:19 AM   #1
cfg83's Avatar
Hello -
Have any of you heard of this? :
http://obddiagnostics.com/
It supports 1996 and later cars and interfaces into your PC (Windows *or* DOS). It also has these modes :
MODE 1: On-board test results, Fuel system status, Fuel trims, Engine load, Coolant temperature, Manifold Pressure, Engine Rpm, Vehicle speed, Timing advance, Intake air temperature, Intake air flow rate, Throttle position, Secondary air status, Oxygen sensor voltages.
MODE 2: This mode retrieves certain data that was saved as a "Freeze frame" at the instant the vehicle set a diagnostic trouble code (DTC).
MODE 3: Reports Powertrain diagnostic trouble codes ("P" codes), including manufacturer specific codes which are reported under this mode.
MODE 4: Clears diagnostic trouble codes. It also clears the result of continuously and non-continuously monitored on board test results (modes 5 and 6), as well as freeze frame data.
MODE 5: Reports On board Oxygen sensor test results.
Most vehicles perform background diagnostics on the oxygen sensors and this mode reports the results. Many vehicles use mode 6 instead to report these results.
MODE 6: Reports On board (non-continuously monitored) test results. This mode reports the results of various tests that the vehicle has performed.
MODE 7: Reports On board monitoring results for continuously monitored systems. These are similar to mode 3 trouble codes, but they are set after a single driving cycle. Sometimes they are called "pending" trouble codes.
It appears to be pretty good for the price.
cfg83 is offline
Old 12-15-2006, 11:22 AM   #2
One of the teamswift.net members is using it and likes it.
It's mentioned in this OBD tool thread also: http://www.gassavers.org/showthread....ght=nerd+alert
MetroMPG is offline
Old 12-15-2006, 11:56 AM   #3
cfg83's Avatar
MetroMPG -
Hmmmm, ok, before posting, I did a search for "obddiagnostics.com" and didn't get any hits. Oh well.
cfg83 is offline
Old 12-15-2006, 12:04 PM   #4
cfg83's Avatar
Hello -
Looks like I just found the same thing. These guys are having a sale on thier box, too :
http://www.scantool.net/
It's the same setup, low cost box, and free SW that runs on your PC.
I llike the DOS option because I can have an ancient/cheapo PC with or without a hard disk. No fear of having it stolen.
EDIT : Maybe not so good after all : "This interface supports the ISO9141-2 and ISO14230-4 protocols used mostly in Chrysler Corporation, European, and Asian vehicles." That's more limited than I thought.
cfg83 is offline
Old 12-15-2006, 01:09 PM   #5
GasSavers_Red's Avatar
Originally Posted by cfg83
Hello -
I have the ELM323 and it's not totally Chrysler compliant. It is handy, however lugging a laptop around all the time becomes a pain
GasSavers_Red is offline
Closed Thread
