Civic VX in Pennsylvania - Page 2 - Fuelly Forums
Go Back   Fuelly Forums > Marketplace | Buy, Sell, Trade > For Sale
Closed Thread
Old 08-30-2006, 08:14 AM   #11
GasSavers_Ryland's Avatar
I would be a bit warry of either of those cars, and would not bid on them unless you had a chance to look them over very closely as they both have bondo.
the one with the blue flames has been repainted, hardly anyone repaints a car and leaves it stock unless it was in an accedent, and they say the title is clear, so the accedent wasn't reported (commen, unless it was really rusty, and repaired, and that could be, if you look at the rear wheel wells they show heaviest signs of bondo.
I paid $1950 for my vx just over a year ago, it had front end damage from being hit while parked, so the photos of it looked horble on E-bay, but I went and looked at it in person, it drove straight, and after being hit again in the same corner while parked last winter I got a new front bumper and some matching spray paint and it all looks pretty good.
if a civic hatch back is going to rust, it's going to rust at the rear wheel wells first, also check the jack points, and spair tire well, if those are solid, and everything looks straight, and it drives straight, then you are doing good, the tranny shouldn't grind in any gears untill 300,000+ miles, and if it was taken care of it should have good compression and clean oil, timing belt and water pump should be changed at the same time every 100,000 mile, the drivers seat will wear, and have a whole where it gets rubed as you get in and out of the car, this seems to happen on every single civic I see.
GasSavers_Ryland is offline
Old 08-30-2006, 10:40 AM   #12
kickflipjr's Avatar
Do the blue flames represent the lean burn?
your killing me.
2008 EPA adjusted:
kickflipjr is offline
Closed Thread
Mobile Page for Smartphones GTGallop Fuelly Web Support and Community News 1 02-23-2011 11:34 AM
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 10:10 PM
Google Earth Help GasSavers_DaX General Discussion (Off-Topic) 5 06-21-2006 12:44 PM
Questions about PCV Compaq888 General Maintenance and Repair 28 06-09-2006 07:27 PM
Civic modified to get 53 mpg. Matt Timion General Fuel Topics 1 09-27-2005 10:57 AM
