Originally Posted by Pete
I have always used Simple Green diluted to around 5 % added to the washer bottle.
So that's just Simple Green 5% and water 95%, or was that Simple Green added to something else?
Originally Posted by 101mpg
Anyone have a recipe for the blue stuff minus the blue coloring?
It's definitely got methanol in it. I'd say any alcohol should work. The point is to force it to evaporate quickly after dispensing it, and to be a solvent that can cut grime.
I found this:
http://www.floras-hideout.com/recipe...d_Washer_Fluid
I CAN find the power washing fluid [...] I suspect it's the same stuff concentrated.
I don't think it is. It smells very different and is more soapy in use. I think I'm going to try it.
My guess - 1 gallon of power washing fluid plus 1 gallon of rubbing alcohol plus 25 gallons of water? Totally a GUESS - but can anyone confirm? The real recipe would be invaluable.
If you only have 1 gallon of each, make 1/4 or 1/2 the recipe and keep the rest so you can raise the concentration easily.
A couple other ideas:
- Any kind of glass/window cleaner, like Windex, especially cheap concentrate from the dollar store or an industrial cleaning supply store.
- Rain-X treatment (not washer fluid) includes instructions for diluting it to use as glass cleaner (like Windex). Perhaps the same formula would work for washer fluid.
I
this thread. I was going to buy some washer fluid at WalMart, but now I'm going to experiment with stuff I have around the house.
