Washing machine noise diagnosis - Fuelly Forums
Old 02-28-2012, 06:56 PM   #1
Unhappy Washing machine noise diagnosis
So I had an average load on an average cycle. It was agitating normally then suddenly this sound started up:
[yt]7UbzWvWXKYQ[/yt]
Does this mean impending doom? Is it an inexpensive DIY repair? Should I just ignore it?
Old 02-29-2012, 04:15 AM   #2
GasSavers_Erik's Avatar
Re: Washing machine noise diagnosis
Are you referring to the medium pitched whine? or to the lower pitched thump, thump....?
The best case scenario would be a frayed belt or a bad idler pulley bearing.
How did it sound on the spin cycle? Any oil underneath the center of the unit?
Old 02-29-2012, 06:13 AM   #3
I'm referring to the whine. The thump is normal. The spin cycle is fine, it's just the agitation cycle that made the noise which started halfway through that cycle.
I'll have to check for oil underneath.
Old 02-29-2012, 08:19 AM   #4
This is what a friend of mine that's a Whirlpool repair man says...
It is always hard to tell when listing to a recording or even over the phone, but I would guess that something is in the water pump. It may go away? I would just keep using the machine unless it brothers him a lot.
On that note, I have pulled stuff out of the water pump on various machines with relative ease. Usually you take the front panel off the machine, and the pump is right there.
Old 02-29-2012, 08:44 AM   #5
Interesting. I didn't realize that the water pump runs during agitation. Perhaps I should look at that.
Old 02-29-2012, 09:00 AM   #6
On some models it does. I remember a former roommate once chewed me out because I "broke" the washer. It was making an objectionable noise after I had used it. When I took the front panel of the machine off, I found the noise was coming from the water pump. When I took it off, I pulled the underwire from a bra out of the pump.
Old 02-29-2012, 01:44 PM   #7
was it her bra, one you "attained," or both?
Old 02-29-2012, 04:34 PM   #8
It wasn't my bra... it was hers.
Old 03-03-2012, 07:51 PM   #9
Well, feeling lazy and apathetic I went ahead and did a couple loads without doing any diagnostic work...no noise. Guess I dodged a bullet.
Old 03-04-2012, 05:29 AM   #10
GasSavers_BEEF's Avatar
sometimes apathy will get you far
Tracking Distance Using the Odometer PTH Fuelly Web Support and Community News 0 08-26-2010 12:32 PM
air intake thoughts GasSavers_ccrider General Fuel Topics 8 11-07-2009 08:05 PM
93 civic vx Cel light on once RPM >3000 ramen General Maintenance and Repair 2 10-30-2008 05:02 PM
CD Question civic lover General Fuel Topics 6 10-01-2008 12:43 PM
Civic And Integra parts + more smoothn For Sale 9 12-07-2007 04:23 PM
