VX upshift light - Fuelly Forums
Old 11-06-2007, 11:31 AM   #1
Matt Timion's Avatar
VX upshift light
Is there anything that would cause the VX upshift light to not work other than the light being burned out?
Old 11-06-2007, 11:44 AM   #2
Member
78si's Avatar
Its a simple ground signal from your ecu. So it could be wiring, or (less likely) the ecu. When I did my ef swap, I ran a wire from ecu pin d18 to the hatch light.
78si is offline   Reply With Quote
Old 11-06-2007, 11:51 AM   #3
GasSavers_TomO's Avatar
If the CEL is on, the shift light won't function either.
Has it suddenly stopped working?
Honda Civic VX Info/Links
Old 11-06-2007, 11:52 AM   #4
The CEL isn't on... but it works (it turns on when I start the car). The upshift light just doesn't work for me at all.
I wonder if a previous owner cut the wire b/c it was annoying or something.
Old 11-06-2007, 11:57 AM   #5
So the upshift light does not come on when the instrument cluster goes through it's bulb check?
Then yes, it's either a burnt out bulb or cut/broken wire.
Old 11-06-2007, 12:17 PM   #6
Danronian's Avatar
Just today I was wondering the same thing regarding my non-working shift light, so I took out the bezel, and looked at the back of the cluster. Not much to my surprise, one of the wire-clips wasn't plugged into the back of the cluster. I plugged it in, and now the shift-light works! Yay! Never had it work before, so hopefully using some guidance from it will improve my shifting for better MPG.
My guess is the previous owner got annoyed of it.
Old 11-06-2007, 12:29 PM   #7
guess what I'm doing in a few minutes?
Old 11-06-2007, 12:34 PM   #8
My predictions:
  • You will check the light during the bulb check
  • You will check out the bulb itself
  • You will check the back of the cluster
  • You will check the wiring to the ECU
  • You will get your shift light to work
Lolz
Old 11-06-2007, 01:11 PM   #9
well, it wasn't the connectors behind the cluster. Guess I'll be checking the ECU later.
I did manage to replace the o2 sensor though. It actually responds a lot better already.
Old 11-06-2007, 01:36 PM   #10
Did you happen to check the light bulb itself with an ohm meter when you had the cluster off?
Tranny fluid flush for FE? brucepick Transmissions and Running Gear 27 07-25-2010 06:03 AM
Congrats to COZX2 on the 100+ MPG fill! MetroMPG General Fuel Topics 58 12-23-2007 08:34 PM
Supermid Arrives! 88HF General Fuel Topics 3 06-23-2007 02:53 PM
Any ideas how to install this? Compaq888 General Maintenance and Repair 0 12-21-2005 01:46 PM
