VX upshift light - Page 2 - Fuelly Forums
Old 11-06-2007, 03:28 PM   #11
krousdb's Avatar
Mine didn't work until I replaced the O2 sensor. Then it worked fine.
Old 11-06-2007, 03:34 PM   #12
Matt Timion's Avatar
Originally Posted by TomO View Post
Did you happen to check the light bulb itself with an ohm meter when you had the cluster off?
Oddly, I didn't see a series of light bulbs in the back of the cluster. I think I saw only 2 in that general area, which is weird considering there are approx 4-5 different dash lights there.
Guess I can remove it tomorrow and see.
Oh, I need to figure out how to remove the brake light in the top of the hatch wing thing. I removed the cover, and the bulb wouldn't budge. I need to fix this before I can pass my safety inspection.
Old 11-06-2007, 06:01 PM   #13
Getting off topic but...
Matt, what source did you buy your new O2 sensor from, and would you recommend them? It seems people have had issues in the past with getting the wrong/defective L1H1 and I need one for my VX as well.
Thanks!
Speed kills...your MPG
GasSavers_Adam is offline   Reply With Quote
Old 11-06-2007, 06:05 PM   #14
He got one with the engine he bought imported from japan,
And another used one he bought on h-t for 25 bucks, as I remember.
Old 11-06-2007, 06:43 PM   #15
actually, the one that came with the engine was cut 1cm from the o2 sensor. The one I got on ebay for $25 was a POS.
I bought one for like $150 on ebay a year or so ago.
I'm really hoping it's just not the placebo effect, but I swear that my acceleration has drastically improved since I put that o2 sensor in.
Old 11-06-2007, 07:00 PM   #16
1cm is a lot of space, man...
Old 11-06-2007, 07:25 PM   #17
not enough... I might still have it if you want it :P
Old 11-06-2007, 07:31 PM   #18
Old 11-07-2007, 03:42 PM   #19
okay... I'm a doofus. I removed the cluster today and there is no bulb in the upshift light area...
Old 11-07-2007, 06:00 PM   #20
GasSavers_TomO's Avatar
no bulb as in, "oh, geez, someone took it out" or "I don't see where the bulb would go for the shift light"?
Honda Civic VX Info/Links
Tranny fluid flush for FE? brucepick Transmissions and Running Gear 27 07-25-2010 06:03 AM
Congrats to COZX2 on the 100+ MPG fill! MetroMPG General Fuel Topics 58 12-23-2007 08:34 PM
Supermid Arrives! 88HF General Fuel Topics 3 06-23-2007 02:53 PM
Any ideas how to install this? Compaq888 General Maintenance and Repair 0 12-21-2005 01:46 PM
