Thermal fuses/cutoffs - Page 2 - Fuelly Forums
Old 07-05-2007, 06:24 AM   #11
A lower temp fuse is the way to go and it prevents the insulation in the fan motor windings from burning and causing a short. If you have a Kill-a-watt or AC amp meter you could measure the stall current of the motor to see how many amps it draws for the amps but the 2 to 2.5 amp increase is not a problem. By all means use some better oil in the fan bushings too like synthetic.
Price form problem thangln Fuelly Web Support and Community News 2 04-27-2011 07:22 PM
ECT Analyzer/manual TC lockup GasSavers_Bruce Transmissions and Running Gear 60 04-01-2008 11:37 AM
Let's start a list of Make:Model:Trim:Modifications:Conditions:MPG! SVOboy General Fuel Topics 44 06-24-2006 12:30 AM
