The pitfalls of statically determinant design - Fuelly Forums
Old 09-06-2007, 01:10 PM   #1
trebuchet03's Avatar
Statically Determinant
A statically determinant beam is a beam where the reaction forces can be found and equations of equilibrium can be solved. More at wikipedia.
So basically, if you remove a support from a determinant design, the structure fails. On the other side of the spectrum, statically indeterminate designs take a bit more to cause failure. That is, by design and definition, an indeterminate design is redundant.
So the WTC towers. It's quite likely we've all seen video of it falling. There's a conspiracy theory floating about that it was demolished, because they fell straight down. First, search for demolition videos. Buildings with a high aspect ratio (that is, much taller than they are in any other dimension) typically DO NOT fall straight down. They twist and topple. As one section fails, other support members try to pick up the slack - but the local load is too great and uneven (causing non uniform collapse).
Okay, so that's out of the way. Lets look at the WTC design.
The WTC towers had a revolutionary design in that it was 100+ stories tall (read: high aspect ratio) with no support beams obstructing your view with the exception of the inner core and outer core structure.
So, how was it supported?
Think of two boxes. The inner core was a very strong structure at the center of each tower. It supported elevators, stairs, services, etc. Then, we have the outer core - what made the exoskeleton portion of the building. At the base of the inner and outer core was thicker material (steel) which tapered off with increasing altitude. This is completely fine as the base will have a greater axial load and bending moment to support.
Floors
Okay, here is where the design becomes revolutionary. Each floor was supported on steel beams. Pinned to the outer core and set on a roller on the inner core. Then, concrete was poured on top of this structure. Roller? There's a reason for this. Buildings with tall aspect ratios have to combat high wind loads. To accommodate this, the inner core was designed such that it would only see axial loading - it would never see a large bending moment transmitted from the outer core. This allows the floor and outer core to move with minimal load placed on the inner core.
On the WTC website, that has since been taken down - the designers showed that their statically determinant design allowed for unobstructed views on any floor of the tower. The design is statically determinant because each floor is supported at two locations - pinned at the outer core and placed on a roller on the inner core.
Here's a diagram from wikipedia
So basic recap
Inner Core - super strong, holds major services, axial load only Supports weight of building
Outer Core - Lightweight, resists wind loads
Both of these systems in themselves are statically indeterminate through use of trusses etc.
So here's what happens....
Plane crashes into building - inner core is compromised, but is still capable of standing.
Fire - heat causes steel to de-temper NOT MELT as some conspiracy theorists would tell you. No, there's not enough heat to melt, but there's more than enough to de-temper thus changing it's structural properties.
Load - the load never changes, but the steel's ability to hold this load does (de-tempering)
Collapse
The design itself was flawed. One would not need an airplane to cause such damage. There's a reason they don't make 'em like that anymore.
Just for comparison, here's the sears tower. This is a redundant design - and I would expect it will take much more damage to cause a collapse. Sure, you'd lose a few floors - but that's it.
Another example is the Oklahoma bombing. While the aspect ratio isn't quite as high... The entire structure didn't collapse - it sort of sheared away from the redundant support.
Let me know if I was rambling or if anything needs clarification....
11/12
Autozone has LED bulbs FormulaTwo General Fuel Topics 16 09-25-2006 02:35 PM
HTMLAREA Matt Timion Fuelly Web Support and Community News 0 09-06-2005 06:41 AM
