Shipping Idea - Page 2 - Fuelly Forums
Old 06-28-2006, 08:20 PM   #11
The thing about the z1 head is that it will give super high compression (~12.3:1 CR) because the z1 has a very small combustion chamber and very dished pistons. You might be able to do it with premium gas, which I've been considering, but Iono. Anyway, yeah, mpfi, dizzy, ecu, la la la.
8 valve goodness will be noted when I get mine done. I just talked to my employer, over the next two weeks I"ll prolly get 125-150 of work time in, so it'll def get done. Just gotta buy the ish, dad's bring my c clamp valve compressors tomorrow,
Old 06-28-2006, 08:22 PM   #12
Good for you! 125-150 hours? Wow. Congrats on finding work, that's what i need.
budomove is offline   Reply With Quote
Old 06-28-2006, 08:24 PM   #13
Dollars, damn, 75 hours a week is nuts. It's just a random job I've had for a while.
Old 06-28-2006, 08:26 PM   #14
Ben, is that a b7 head on it or b8? which is going on there? Is the bottom of the engine sstill from your stock 16 valve?
Old 06-28-2006, 08:27 PM   #15
better than no dollars.
Old 06-28-2006, 08:28 PM   #16
The b7 head is just a donor, the b8 will be going on, and the block will stay stock b2.
Old 06-28-2006, 08:30 PM   #17
It still has the b2 head on there then? You got 59.? mpg with a 16 valve?!
Old 06-28-2006, 08:31 PM   #18
b2 is on there, I've not gotten 59 to a tank, my best segment is still just 59.3,
Old 06-28-2006, 08:33 PM   #19
And you have an si mpfi im on there? Don't you need an hf one?
If I wanted to go mpfi, i would need the si one, but then couldn't hook that up to an 8 valve if i decided to swap heads later, huh?
Old 06-28-2006, 08:36 PM   #20
I have dan's I think, the rather neutral manifold. The funny thing about 8 valve stuff is that it's almost always free, like everything I have that came off an 8 valve engine that I own,
No internet, can i just save the refueling data? VASILI Fuelly Web Support and Community News 3 11-07-2013 10:23 AM
Help Needed! thewolfwagon Fuelly Web Support and Community News 2 05-17-2012 05:44 PM
Car not showing in browse vehicles Armegatron Fuelly Web Support and Community News 1 01-17-2012 04:15 AM
Fuelly for international? pixelthing Fuelly Web Support and Community News 8 08-11-2008 08:32 AM
OBDII Questions krousdb General Maintenance and Repair 1 05-07-2006 05:18 AM
