FINALLY another Tempo/Topaz owner!  Very presentable car for $200. I figgered you named it Gloria because it's obviously such a glorious machine... right?
Yeah, glorious for sure
. The name Gloria just seemed to fit the car real well and Laura Branigan's Song "Gloria" was one of the first I heard on the Tempo's radio.
I can hardly wait to see what FE YOU get out of her!
Me too. For the first little while I'm going to take my MPG as a grain of salt since the gas gauge seems a bit wonkey (it only read 2/3rds of a tank when I first filled up) but eventually the law of averages will show its true colours.
Off the top of my head, I don't recall if '88s had throttle body or multi point EFI. I think it's MEFI but it still is a different system than the '92s. My only experience is with the U.S. '84s with emission carbs (hateful damned things when they aren't working right) and the '92s with MEFI (my experience is this is a very reliable system). I understand early Canadian T/Ts had regular carbs and ignitions- probably a better idea.
You're right. according to
www.tempotopaz.com, Canadian T/T's had carbuerators up until 1987. I'm pretty certain that the 1988 models and up had multi-point fuel injection.
I have found T/Ts to be quite comfortable; in particular the seats fit me perfectly and the ride quality and handling is very good although 50 psi tires along with new struts and my 15% stiffer springs and reduced suspension travel in compression allow a bit of harshness. Even so the ride is more luxurious than a Metro for sure. Someday I'll have good tires on the Topaz and will air them up to 50 and keep the old, soft struts and see how that works. Some T/Ts experience sagging rear springs for some reason. My Tempo did not but the Spaz is a bit saggy in the rear. I intend to lower the Spaz too but due to its' sagginess I will adjust my spring cutting accordingly.
Gloria is definitely suffering from the sagging rear end syndrome. It's really not bad until she hits a speed bump though. Maybe I'll lower the front end to compensate for the rear. Overall, even in its current state, it's a very nice car and I can see how they were so popular when they were brand new. 0.36 Cd in the Tempo is much better than the 0.40 for an early 90s Cavalier (and I think the Dodge Shadow was the same 0.40 If I recall correctly).
One thing is for sure: my Geo struggles to do 65mph in the wind, but the Tempo just loves it. I've tried to do the same 50mph I did in the Geo with Gloria, but it's just too easy for her!
Edit: I just removed Gloria's passenger side front seat today. Man alive that thing was heavy!
Attachment 875Attachment 884
There used to be a great weight reduction thread here on GS (complete with pictures), but I can't find it. Anyone know where it is?
