OdieTurbo lost his PC! - Fuelly Forums
Old 07-17-2007, 06:21 AM   #1
OdieTurbo's Avatar
Send a message via Yahoo to OdieTurbo
Fellow GasSaver dudes (and dudettes)! My PC went down last weekend and I still don't have it up. I can only get on at work and at mom's PC when I get a chance .
Has anyone here ever used a data recovery service? My hard drive is dead, but I've got like 40GB of stuff I would really like to get off of it. Wondered if anyone had any experience like this.
Until I get my PC frankensteined up again, I can only post sporadically.
2005 Saturn VUE 2.2L 5-Speed FWD
OdieTurbo is offline   Reply With Quote
Old 07-17-2007, 07:01 AM   #2
How do you know your hard drive is dead?
Usually hard drives give signs before dying as well.
I know this is late, but obviously if the data was that important... back-up-> back-up.
Could be just your boot table. If the HD is really on your last legs, there's always the freezer trick to see if you can get it to boot and backup your files.
At home, I personally run a raid 1 (mirrored) array, and backup to an external hard drive monthly. Does not really help me of course if my house burns down, but than o well to that.
My Photosite My Photoblog
bbgobie is offline   Reply With Quote
Old 07-17-2007, 07:18 AM   #3
Hockey4mnhs's Avatar
yup same thing happend to me a little bit ago. i lost all my music and info i need i just had to start over.
Old 07-17-2007, 07:50 AM   #4
OdieTurbo's Avatar
Originally Posted by bbgobie View Post
How do you know your hard drive is dead? Usually hard drives give signs before dying as well.
Went to boot it up, incessant clicking noise, then a message saying no bootable device present.
Yeah, I had JUST bought a pack of blank DVD's and was set to back up this past weekend
I think it's way past that. Something sounds broken inside the drive.
Next investment - raid array...
Thanks though!
Old 07-17-2007, 09:36 AM   #5
GasSavers_Red's Avatar
What kind of clicking noise? Like a relay click or the hard drive reading click? If its the relay click then the drive is toast as something internal went out on you.
Old 07-17-2007, 10:24 AM   #6
CoyoteX's Avatar
If possible take the hard drive and stick it in another computer as the secondary drive. It is possible the motherboard ide controller has died or the power supply is not working properly. You will know in a few seconds if it works or the drive is actually dead. Feel the drive and make sure the platters are spinning. If they aren't spinning laying it flat on a table then spin the entire drive as hard as you can then stop it spinning instantly to help break the platters free. Usually clicking means the only way to get the data off is to find an identical drive and swap the platters out when it dies like that. Swapping platters and having it work is pretty hard to actually do though but if the data is worth that much then that or sending it to a data recovery place for $$$$$ are really your only options.
Old 07-17-2007, 10:36 AM   #7
Yeah, the places I've heard of are mucho $$$.
Its weird, of the 10 or say hard drives i've had fail, there was always symptoms first...
Old 07-17-2007, 11:43 AM   #8
CO ZX2's Avatar
Symptoms?
I have no help to offer here but....
What are the warning signs of impending hard drive failure? Knowing this may help a lot of folks avoid what Odie is experiencing. Thanks.
Old 07-17-2007, 11:56 AM   #9
....Has anyone here ever used a data recovery service? My hard drive is dead, but I've got like 40GB of stuff I would really like to get off of it. Wondered if anyone had any experience like this.
I know that OnTrack does stuff like this. Weve used them but at a cost of about $2300 for a typical laptop hard drive. I dont know if a desktop drive (which Im assuming is easier to work with) is any cheaper.
The suggestion to SLAVE the drive using another PC is a good suggestion. Actually, since you need another drive anyway, reinstall Windows with another hard drive and when you get it up and running, slave the old drive and see what happens. You MIGHT temporarily be able to access the drive but it sounds real iffy right now. Another option is to hook the old drive to another machine using an external enclosure. I have been able to recover data off drives but usually when that clicking sound is present you are dead out of the water. MAYBE (BIG maybe, you will be able to access for a shirt time). Good luck
Conclusion: Setup PC with new hard drive and either slave old drive with IDE or external enclosure. If you data is software GOLD, then recover data for 2 grand plus.
GasSavers_StanleyD is offline   Reply With Quote
Old 07-17-2007, 12:03 PM   #10
If your hard drive is making a lot of noise when you boot it up (actually it will make noise when you are using it as well) then it will probably die soon. Given the relatively small cost of new drives, then you should DEFINITELY backup and replace drive asap. BTW, dont confuse hard drive noise with fan noise coming from case fans or power supply fans. Hard drive fans typically are a little more high pitched than other fan noises which are sometimes making noise because the blade is rubbing against something.
Replacing your drive will mean reinstalling your OS (XP/Vista or 2000) which will take about two hours plus the time to reinstall your personal software and programs, but is a small price to pay in comparison to the headache of replcing AFTER a hard drive failure occurs. The best options besides backing up are using RAID or 'ghosting' your machine which will get your PC back to its last saved state in under half an hour. This can be done using Norton Ghost.
Saturn Sports Coupe Aerodynamics Peakster Aerodynamics 34 06-16-2013 08:08 AM
95metro about to conduct ambitious (blind & controlled) acetone test - cancelled MetroMPG Experiments, Modifications and DIY 14 11-21-2006 10:16 AM
