New Guy! Recommendations for a Pre-1996 fuel efficient car? - Page 3 - Fuelly Forums
Old 05-01-2006, 11:37 AM   #21
krousdb's Avatar
Re: Also, the crx has a much
Originally Posted by SVOboy
Also, the crx has a much lower coefficient of drag than other hondas.
Dan, 3.25 is correct for the cx final drive, the final drive for my 5 speed will be 2.95,
Relieved, but still jealous of yours.
Did you see the D15B8 torque peak was at 2000 RPM? :jawdrop:
Old 05-01-2006, 11:43 AM   #22
switch hf fd?
Are you taking a 2.95 fd and putting it in an hf trans? I like it.
budomove is offline   Reply With Quote
Old 05-01-2006, 11:46 AM   #23
krousdb's Avatar
Re: Thanks Guys for all the
Originally Posted by kozaz
CX - 70hp, 1.5L 8-valve non-VTEC ****box engine
Don't underestimate the hypermiling potential of a ****box.
Old 05-01-2006, 11:48 AM   #24
krousdb's Avatar
Re: switch hf fd?
No, the 88-91 CRX HF's came with 2.95 FD. They differ from the 92-95 trannys because the clutch is cable activated instead of hydraulically activated.
Old 05-01-2006, 04:17 PM   #25
They also differ in
They also differ in mounting. That ****box engine will be my new engine,
Old 05-01-2006, 04:25 PM   #26
krousdb's Avatar
Re: They also differ in
And the next one you find will be mine.
Old 05-02-2006, 09:29 AM   #27
Re: 1988-1991 CRX HF 1-2k,
Older CRX HF's are usually in worse shape and require a little bit more work. To make it a real gas mileage monster you'll need to swap out the engine and swap in a d15z1 engine. This includes the ECU, distributor, etc. This isn't totally needed toget you over 50mpg, but it will get you over 60mpg.
I'm trying to way out all my options, I can regularly buy 88-91 CRXs locally for under $2500, and even $900-1500 for some that need work.
With a little reseach I just realized that the CRX HF is geared for better fuel economy. If I do the engine swap, I assume I will not need that model, except for maybe some of the other HF Options (Like light wheels???)?
Without getting into engine swap details (I'm sure it is well documented on the internet), what advantage does the 92-95 Civic VX d15z1 engine have over the stock 88-91 CRX HF engine? (Let's say both are running at their peak efficency).
Great Info Guys!
Keep it coming!
kozaz is offline   Reply With Quote
Old 05-02-2006, 02:35 PM   #28
The z1 has a bit of interior
The z1 has a bit of interior design but also has vtec, which virtually shuts off 4 intake valves under 3k rpms. It can also run much leaner and has things like roller rockers to reduce friction.
Old 05-02-2006, 02:47 PM   #29
Matt Timion's Avatar
SVOBoy is right. The d15z1
SVOBoy is right. The d15z1 (civic VX engine) has a unique design that actually can allow for air fuel ratios of 20:1. Below 3000 RPM one of the valves is only slightly open which actually causes a "swirling" action that helps promote leaner AFRs as well.
The d15z1 also has a 5-wire wideband oxygen sensor which can give better feedback and help achieve high AFR.
Oh, and it gets better power than the stock crx hf engine, so it won't seem so slow.
If you put a d15z1 engine into a civic/crx/etc made between 1988 and 1991 you'll need to get a transmission from a 1988-1991 car. (the 1988 is unique, the 1989-1991 are interchangeable)
I have a CRX HF transmission from a 1991 and will be mounting it to my d15z1 sometime soon. It will work in my 1989 civic sedan with no problems.
Plus, the d15z1 is obd1 and is a little cooler.
the crx hf engine is just an 8-valve engine.
Old 05-03-2006, 07:10 AM   #30
GasSavers_Ryland's Avatar
as far as I've been able to
as far as I've been able to tell, the crx hf only came with steel rims, not sure what alloy of steel they used, but the steel rims from my crx hf are a few pounds lighter then the stock steel rims from my civic.
the popular answer you are going to get for rims is going to be civic vx, hx, or honda insight rims, there was also one modle of Miata rim that weighed around 12 pounds, and had the same bolt pattern, but I'm not sure about wheel offset.
If I had the time, and money ($3000 should defently be enough) and didn't need a back seat, and could find any crx's around here (there is maybe one for sale per month) I would get one, and swap a vx engine in to it, and just like the civic modles, the si is heaviest and base modle is lighter, and fuel effiecent modle is lightest.
one of the other things that both the crx hf and civic vx don't have that make them lighter, is a sway bar, and if you live in Nebraska or other windy states, you might notice that it's a little harder to handle in crose winds.
New cars don't get along with fuelly mlocklear Fuelly Web Support and Community News 5 06-13-2009 04:27 AM
Condensator orevgym General Fuel Topics 0 07-23-2006 11:25 AM
