If the inability to use the shelving because it's on it's side causes you to dig around in there longer before you extract what you want, is there any savings?
The thing is so shallow to begin with.... So I'd say no. I mean, it's no worse than having to reach really far back into refrigerator to grab a lone pickle jar
If it were any deeper - I'd add sliding shelves
Since my last post, I've moved my fruits/veggies, lunch stuffs, boiled eggs, bread and some juices into the mini fridge. I kept the spirits in the freezer area - I think it will act as a suitable heat sink.
I'm also considering a very small circulation fan as I've noticed a temperature gradient between the top and bottom - nothing too big, but I think there's room for improvement. I think a small fan (low power/compact) + door switch will resolve this issue.
And while I'm at it, a fan to blow off some of the compressor heat -- the temperature in the compressor box area was around 80 degrees. Heat I don't want rising into the chill zone
