Mag Light - Fuelly Forums
Old 11-13-2009, 08:57 AM   #1
Mag Light
I have an old 3-cell Mag light that is very useful this time of year when I have to look for addresses in the dark.
Problem has always been that Mag Light flashlights suck-up batteries and a weak yellow beam doesn't do much illuminating.
So, yesterday I bought a LED replacement bulb. My hope was for extended battery life and I was praying it would still be adjustable and might have at least some of the range of the original.
WOW!
The sucker is waaay better!
It now casts an almost laser tight beam of bright white light a hundred yards.
Old 11-13-2009, 10:00 AM   #2
I have at least 3 mag lights. Thanks for the tip.
Old 11-13-2009, 10:02 AM   #3
Yeah, the LED conversion on the Mag Lites is well worth it. Pretty much pays for itself after about 4-6 hours of use, where you'd have to replace the batteries if you didn't convert.
Old 11-13-2009, 10:05 AM   #4
Where does one get the LED bulb?
Old 11-13-2009, 11:07 AM   #5
If you have an account with Grainger it looks like they have them...
http://www.grainger.com/Grainger/items/2ELA6
Old 11-13-2009, 03:23 PM   #6
UPDATE!
The Ace Hardware salesman said; "lets see if it works." It did, so I bought it.
I wondered .... and called MagLite and asked if there was anything wrong with using their 3watt LED for a 4-cell light in my 3-cell MagLite,
and I was told that the proper bulb for the 3-cell would perform better and use less power.
Then I discovered Ace Hardware doesn't normally carry the MagLite replacement bulb. I had found the only one that had their own stash.
Mag Lite:
http://www.maglite.com/storelocator.asp
Old 11-13-2009, 04:38 PM   #7
I remember the 5 cell mag lites I used to use on the ambulance.
Old 11-13-2009, 08:06 PM   #8
GasSavers_JoeBob's Avatar
I know Harbor Freight sell the Mag-Lite with the LED...I think they sell the replacement as well. I'll have to check and maybe get one for mine (if I can find it...)
Old 11-14-2009, 10:30 AM   #9
I just went and got a Lithium powered Luxon 230 lumins adjustable flashlight - a little pricy but well worth the extra because of the adjustable beam intensity. The highest setting it lasts for 4 hours the lowest setting about a week of continuous use and is bright enough to read with. With the reflector removed the beam is 90 degrees of incredible light that is even and will light up a 6 foot spot on the ground almost like daylight. It runs on a single 18650 lithium "laptop" cell or two 123A cells.
Attachment 1659
Specifications:
LED Type: Cree 7090 XR-E Q5, 3W
Battery: Compatible for 2 X CR123A,1 X 18650, 2 X 16340 or 1 X 17670
Weight: 165 g without batteries
Accessories: One lanyard , one holster, two spare O-rings, one spare tail cap rubber boot
Old 12-31-2009, 03:40 PM   #10
I was just digging through some old threads and I saw this... I just picked up a 2D LED Maglite at Grainger a few weeks ago. I think its the best flashlight I've ever owned!
Handheld Flashlight, LED, 2 D Batteries
* Lighting
* > Flashlights
* > Handheld Flashlights
Handheld Flashlight, LED, D Battery Size, Number of Batteries 2, Length 10 In., Dia. 2 1/4 In., LED Lamp Type, Body Color Black, Body Material Aluminum, Switch Type Push Button 3 Position Switch, Polycarbonate Lens
Grainger Item # 2ELA9
Your Price (ea.) $43.70
Brand MAG-LITE
Mfr. Model # TT2D016K
Ship Qty. 1
Sell Qty. (Will-Call) 1
Ship Weight (lbs.) 0.97
Usually Ships** Today
Catalog Page No. 610 catalog
Country of Origin USA
[Handheld Flashlight, LED, D Battery Size, Number of Batteries 2, Length 10 In., Dia. 2 1/4 In., LED Lamp Type, Body Color Black, Body Material Aluminum, Switch Type Push Button 3 Position Switch, Polycarbonate Lens]
Enlarge Image
WTB: VX instrument cluster with SIL and tach Reborn996 Wanted to Buy 3 08-26-2008 10:12 PM
MINT 1989 CRX with 34K miles! 70DIMER For Sale 2 03-17-2008 11:33 AM
Congrats to COZX2 on the 100+ MPG fill! MetroMPG General Fuel Topics 58 12-23-2007 08:34 PM
compressed air car MetroMPG Electric and Solar powered 7 04-09-2006 11:59 PM
Any ideas how to install this? Compaq888 General Maintenance and Repair 0 12-21-2005 01:46 PM
