low power computers - Page 2 - Fuelly Forums
Old 01-21-2008, 07:11 PM   #11
skewbe's Avatar
I got another laptop working, a 1ghz freebie (had to install a new power thingamajiggie for $15). It runs at 25 watts with the wireless card and laser mouse even.
Standard Disclaimer
Old 01-23-2008, 11:48 AM   #12
Mentalic's Avatar
I picked up an old Compaq P3 small form factor off Ebay the other day for $6.19, shipped for another $29. I set it up running a Linux firewall distribution called IPCOP. Its very quite and only pulls 34.6 watts booted up and running the firewall software. Now thats low power low cost.
The funny thing is how much a "powered off" computer uses in this day of wake on demand systems. It still was pulling 24 watts in the shutdown condition!
Mentalic is offline   Reply With Quote
Old 01-24-2008, 09:54 AM   #13
My $40 e-bay toshiba laptop (66 MHz, P266, 90 MB ram, 12.1 inch TFT, 30 Gb HDD) didn't come with a power supply, so I am making do with a 12v, 1 amp rated output power supply from some broken project or other.
The LiIon battery runs it for over 2 hours with a modicum of power saving settings, and takes seemingly forever to recharge when in operation. I suspect the AC/DC supply I'm using is barely enough to run the brick, let alone recharge it at the same time. That leads me to believe it is consuming not more than about 15 watts at full tilt, or as full tilt as 266 Mhz can be. The AC input to the converter is probably closer to 20 watts as a guess.
Old 01-24-2008, 09:08 PM   #14
omgwtfbyobbq's Avatar
Originally Posted by kickflipjr View Post
belivie it or not wal-mart sells a really low power lunix compter for $199. I don't think I would buy it because it doesn't even come with a cd drive.
The mobo/proc goes for $60.
http://clubit.com/product_detail.cfm?itemno=A4842001
It kinda sucks because the PowerSaver feature of other Via procs doesn't work, but even then it only uses ~35W under normal use with a porky IDI hard disk, so I'm guessing it'll idle at 25W *(17W now) or so w/ a notebook hard disk. Mine sucks down 45+W *(35+W ) 24/7 running stuff from climateprediction.net. All the hardware is supported under Linux and it's surprisingly quick considering. It may use a third of the power most desktops use, but it's no where near that slow.
*I added a 80 PLUS power supply for ~$4 AR which cut ~10W off across the board.
Old 06-20-2008, 09:30 AM   #15
GasSavers_hypermile's Avatar
linux is generally better at using system resources than windows is, and if you do the majority of your work online instead of using windows programs you should be just fine. I use Ubuntu (a version of linux) and it fits my needs just fine, plus it's free
GasSavers_hypermile is offline   Reply With Quote
Old 08-09-2008, 07:06 PM   #16
Me too. I have Ubuntu 8.04 running on my Acer Aspire, and have Xubuntu running on a couple of old Gateway Solo PIIs w/ 196 megs RAM.
Sporkman is offline   Reply With Quote
Looks like the price you entered for a litre of gas is unrealistic. winstona Fuelly Web Support and Community News 6 05-12-2013 11:26 AM
Diesels are very efficent at idle? philmcneal Diesels 36 04-05-2007 07:25 PM
2006 Honda Civic sedan automatic MetroMPG Car Reviews 10 03-13-2007 08:22 PM
Electric bikes banned in Chinese city to make room for cars MetroMPG Electric and Solar powered 4 11-24-2006 08:29 AM
Recommendations for a tire gauge Compaq888 General Fuel Topics 10 04-21-2006 03:18 AM
