10-16-2006, 04:29 AM
Low gas consumption :-(
I really need to get a SuperMid for my swift. !
It has been 2 months since my last tank fill and I still have another 100km to go before I can fill up again and calculate my latest whole tank FE figure.
If I fill at half a tank or a quater I am more likely to get pump fill errors and a worse average compared to full fills.
If only my car had excessive fuel consumption , then it would be easier to see it and reduce it.
Man that sounds so whacked
10-16-2006, 04:51 AM
Frequent filling shouldn't affect your overall (running) average.
(Unless you're saying that the pump itself is the problem, vs. inconsistencies in the level you fill to in your tank.)
10-16-2006, 05:02 AM
MetroMPG
Yup , inconsistant fill amounts can fuzz the numbers.
10-16-2006, 05:10 AM
Doesn't it all average out in the end? If you underfill this tank and calculate extra-good-high MPG, your next tank will take a little more to fill, making its calculated MPG lower. But your cumulative MPG will be accurate, won't it?
10-16-2006, 05:42 AM
MetroMPG -¨Doesn't it all average out in the end?¨
Not really ... Only if you can be assured that you are filling up the exact same level every time.
I fill up the filler pipe to the very top , but there still may be pockets of air trapped in the tank.
This could be as much as a litre of air instead of gas.
If my small top up fill was only 5 liters in total then I could have an error of 25%.
That , or whatever error amount over 1 whole tank full of 35 litres would give a possible error of only 3%.
If because of the shape of the tank trapped air is present when filling up you could get a variation depending upon how much of this air that is purged.
I had 1 car (many moons ago) that if you filled it up rite to the top and then rocked the side of the car violently a few times the fuel would drop in the filler neck by at least 3 litres. (conservative , I think 5 litres)
Because of this possible variation you never knew if full is trully full.
I didnt do it often (only for trips) because it looked like I was humping my car.
10-16-2006, 05:54 AM
Car Porn
ROTFLOL!
10-16-2006, 06:01 AM
Also ,,if my memory is still good ..on some cars (i know Nissan did this) they used an extra small tank , of about 10 litres in size to take fuel when it expands when heated.
It was a small tank mounted above the main fuel tank fed by tubes to the main tank.
Its not intended to be filled with gas when filling up , but it does take a little.
You would never get accurate fill volumes as sometimes this extra tank would take some gas liquid as well - and sometimes not.
Funny
... But I still think it averages out in the end with cumulative fuel consumption (in a normal car with a single tank). I agree your tank to tank variation can be higher with small fill-ups (and if those figures are your concern - eg for testing purposes - fair enough.)
I still think the long term figure over several to many tanks is reliable, regardless of fill amounts.
10-16-2006, 06:16 AM
MetroMPG
Over many many whole tanks it probably work out better , but not with top ups.
Of course with a MPG computer this is totally irelevant as it doesnt require you to rely on the tank as being as relaible capacity.
I will explain it with another example.
I fill up the car but unknown to me there is say 5 litres of trapped air in the tank which does not get filled with gas.
I drive my hundreds of miles noting the before and after reading.
I then refill the car and take down the litres filled , but this time perhaps due to a differnet parking angle of the car , air is vented from the tank.
I now fill an extra 5 litres into my tank than on the previous occasion.
I calculate the FE figure results ,, and it looks like that I have used 5 litres more gas since my last fill up.
again ,, from full tank to another , its not too big a problem , but if you run this scenerio again but using 1/4 tank FE tests the error could be huge.
On the next FE test it could look like you have used 5 litres less fuel - you cant experiment with so much variation, especially when it looks like I have just saved 5 litres over a quater of a tank.
Of course not all cars would be like this , some wil fill completely ,,but surely some still have this problem.
10-16-2006, 06:28 AM
I wonder if our tanks are very different.
I've never had this problem with my Suzukiclone when filling at the same pump, parked in the same spot - that's the key.
Out of the box, the ScanGauge and the pump were within a couple per cent of each other - and the error was in the ScanGauge, not the fill amount. I've been able to calibrate the SG so that recent fills show only a 0.5% discrepancy.
How many liters is your car's tank? Mine's 40 / 10.5 US gal.
EDIT: my fills are typically between 10 to 20 liters. I think you'd be safe doing this if you used the same pump & parking spot for each fill.
