You can buy solar powered fan roof vents as well, they do cost a bit more but are self contaned so they will save you the cost of wiring, and save you on your electric bill.
The ground is pretty close to 55F all year round once you get below the frost line, the main reason for insulating the foundation of a house is to keep the cold from the frozen ground out, so in the summer nearly all that heat is coming from above, like was said, white, silver, grey, or any other light/reflective color will help keep your house cool in the summer, and in the winter those light colors will help keep the snow on your roof, and that snow will act, to a point, as insulation, keeping your roof 30F insted of the -10 that it might be outside.
while you are adding insulation to your atic, make sure that you don't block off any vents to the outside that might be in your eves, you can buy chanals that keep that space from filling with insulation so that you keep air in that unheated space moving, and most roof vents are labled with how many cubic feet of space they can vent so do your best to make sure you have enough.
