Insight almost ate it today......at home! - Fuelly Forums
Old 12-03-2006, 06:43 PM   #1
BumblingB's Avatar
While doing a bit of prep work for my upcoming garage I almost killed my Insight today. I needed to remove a tree so had been digging a hole hole around the base in hopes of pushing it over with my tractor like I've done before. It didn't want to move and I had already dug about 6 feet down so I finally gave my father the go ahead to take it down.
Earlier in the day he said I should move the Insight, I told between the 2 of us we have close to 100 years experience in taking trees down and I trusted him with the chainsaw. I hopped on the tractor and applied pressure to the tree so it would fall in the right direct. Also the wind was in our favor too (AWAY from the car and house). A few minutes later and my dad stops and says, "Come look at this, I think I screwed up." So I put the tractor in "crawl" and hop off. Sure enough he made the cut wrong and now the tree was leaning in the wrong direction! I was so into making sure the tree wouldn't fall in the wrong direction I forgot about the car so I made a cut I thought could maybe repair what he had done. I made him step back a few feet and told him I would be using my catlike reflexs to sure nothing happened to me if the tree feel in the wrong direction. Well, Murphy's Law kicked in and the tree came down. We were VERY lucky! No injuries, a higher power was looking out for me. It also missed a power line by about 2 feet.
A couple of light scratches on the hood
My tractor wasn't so lucky, it suffered a bent fender but now I can get on and off easier - they should of made it that angle from the factory
BumblingB is offline   Reply With Quote
Old 12-03-2006, 07:12 PM   #2
Spule 4's Avatar
VERY lucky, and better the tractor than you or your friend. A friend had two trees fall during a storm in his backyard here in Nashville, both landed on either side of his two cars.
"Knowledge is Good"
-Emil Faber
Spule 4 is offline   Reply With Quote
Old 12-04-2006, 09:36 AM   #3
GasSavers_Jack's Avatar
Just goes to show how dangerous cutting down trees is. Glad everything turned out mostly alright.
See my car here:
Old 12-04-2006, 10:07 AM   #4
philmcneal's Avatar
ya if the wind was nasty... who knows what would have happened.... good to hear you all are all right! That's what you get for messing around with mother nature
Old 12-04-2006, 02:47 PM   #5
BumblingB's Avatar
Sad thing about it was just how much the wind was in my favor. I told my dad he is no longer doing the cuts when we down a tree. The only reason the tree is still there was I took down minimal trees when I first cleared my lot. Now I found out I need to bring 2 down. The 41 year old pine that landed on the tractor and a 10-12 year old Live Oak that will come down next weekend. Everything else that will be built on the property will be built around the trees. The garage was the exception due to its sheer size - not quite my "dream garage" but close to it.
Can no longer add fuel-ups with LG Viewty RolandOfAwesome Fuelly Web Support and Community News 2 09-15-2008 05:41 AM
avg miles per... carol5 Fuelly Web Support and Community News 2 08-08-2008 04:20 AM
Just ordered some VX rims...... GasSavers_Jack General Fuel Topics 20 06-10-2006 06:17 PM
TSB-Technical Service Bulletin Compaq888 General Maintenance and Repair 5 03-20-2006 09:12 AM
Mad Driver GasSavers_KenS Introduce Yourself - New member Welcome 4 12-27-2005 08:49 AM
