Honda Civic VX Info and Links - Fuelly Forums
Old 04-29-2007, 09:15 PM   #1
GasSavers_TomO's Avatar
Exclamation Honda Civic VX Info and Links
I am going to try and collaborate all the info on this board pertaining to the Honda Civic VX into one post in an attempt to make searches easier for this model of car. this will be continually updated as I have time to do so. Input and links are always a welcomed contribution.
About the VX:
VIN Info for the VX
Why the VX is great for FE highway driving
Things to look for when buying a VX
Stock Colors of the VX
Aerodynamics:
Civic Hatchback Aerodynamics
Opening the Rear Hatch
Ebay:
Search for D15Z1
Oxygen Sensor Search
Engine:
Replacement Engine Sources
GM Top Engine Cleaner part#1052626 (available from your local GM dealer) for de-carbonizing the engine. HOW-TO with Seafoam. You can use either product for de-carbonizing...I prefer GM Top Engine Cleaner as it is O2 sensor safe. I use a different method of application. I remove the intake tube and spray in the cleaner with THIS.
Converting a CA emissions VX to 49 States Lean Burn
VX Exhaust discussion
Lean Burn:
Lean Burn Monitor Info (also contains info on spark plugs, PCV system, theory, and more. It's kind of a catch-most thread. VERY highly recommended reading!)
Parts:
OEM Parts online links
Reviews:
Review of the VX by Ryland
Aftermarket Intake on a VX
Rust:
Rust Repair Info
Suspension:
Replacing Rear Hub
Transmission:
Identifying a CX/VX transmission
Weight Savings:
Aluminum drums to save ~3lbs.
Weight of VX wheels
Misc and How-To:
Valve Lash Adjustment
DIY: PVC PCV Catch Can on the cheap
DIY: Make an Aftermarket PCV into an OEM VX PCV
How-To: Cleaning the EGR ports - For an accord but similar for a Civic.
How-To: Clean your IACV
EACV blow-through FYI
How-To: Intermittent Wipers
Hood latch fix and Oil burning discussion
Civic fuel gauge inaccuracy thread
keywords:
d15z1 PCV postive crank vent valve VX emissions hose Civic Honda d-series d15 VTEC VTEC-E idle blue Fram DIY how-to how to mpg FE modify info Lean Burn Monitor LAF wipers intermittent help gauge fuel
Honda Civic VX Info/Links
Old 06-20-2007, 06:29 PM   #2
kwtorbe's Avatar
I have been unable to find the lift/duration of the VX camshaft. I thought I saw it on gassavers once.... Do you know this information and could you link it if you find it on gassavers?
kwtorbe is offline   Reply With Quote
Old 06-20-2007, 08:13 PM   #3
I did some searching and couldn't come up with anything on the VX cam specs. I'll look further into it and get to posting the info I find.
Old 06-26-2007, 01:36 PM   #4
Sigifrith's Avatar
Do you know what the difference is in the 92 - 93 ECU, & the 94 - 95 ECU?
I find 2 different part numbers for 49 state models at San Leandro Honda. Are they interchangeable, or do you need to use the correct one for your model year?
[SIGPIC][/SIGPIC]
Sigifrith is offline   Reply With Quote
Old 06-26-2007, 08:29 PM   #5
It looks like the 92-93 uses the original revision of the ECu and the 94-95 used the the first revision.
I have tested one of the original revisions in my VX and it works fine. I have it for sale too if you need a replacement ECU.
Old 07-03-2007, 10:17 PM   #6
kwtorbe's Avatar
From the Haynes for 96-00 I know these specs for the VTEC-E camshaft in the Civic HX (D16y5):
Lobe height:
Intake:
primary------1.5129 inches
secondary---1.2674 inches
Exhaust-------1.5269 inches
I was unable to find duration/lift values.
I have an HX and would like to install a VX camshaft. I have one already, but it is in Tulsa in storage so I need to know if this is worth pursuing.
Do you have a Haynes or Chiltons that would give the lobe height for rebuild?
Thanks.
Old 07-04-2007, 07:41 AM   #7
Sigifrith's Avatar
From my 1992 Edition page 6-42
D15Z1
Intake
Primary 1.5129
Secondary 1.2713
Exhaust 1.4960
From my 1993 Edition page 6-42
D15Z1
Intake
Primary 1.5129
Secondary 1.2713
Exhaust 1.4959
[SIGPIC][/SIGPIC]
Old 10-29-2007, 10:42 AM   #8
Danronian's Avatar
Might want to add this pcv valve discussion to here:
http://www.gassavers.org/showthread.php?t=5455
Old 11-04-2007, 09:17 PM   #9
I added some new links.
Old 11-08-2007, 01:07 PM   #10
93dagsr's Avatar
where can i buy one?? this is the D15Z1 right?? i been looking for one to drop into my 88 crx but nobody has the complete swap, motor, tranny, ecu, axles and shift linkage.
https://consumerguideauto.howstuffwor...onda-civic.htm
stupid ricer... useless wings are for pinguins!
93dagsr is offline   Reply With Quote
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 04:13 AM
Search feature added Matt Timion Fuelly Web Support and Community News 1 09-26-2005 03:02 PM
