Here's The Problem - What Would You Do? - Fuelly Forums
Old 01-10-2011, 05:24 PM   #1
Clyde The Ride, my 2006 Tundra, sprung a leak.
Well, specifically, a head gasket sprung a leak and now the engine is oiled on the outside too.
Oiled seriously enough that my once pristine parking spot now has a heavy coating of oil spots and I use a quart of oil in a bit over 500 miles. Crud.
So, what to do?
I still owe $9,000.00 so using it as a trade-in would probably mean payments far beyond what I now have.
Then I would have high payments and only a mile or two better mileage to compensate.
I could do a half-*** repair and just throw on a gasket, but I am totally disinclined to do the work myself and 80% of doing the job right
only to find that the head needed to be plained or there was a bad valve, and Dex won't do the job wrong, so that looks like a bad plan.
Dex says he will remove the engine and send the heads out for a valve job,
then he'll replace the rings, reminding me that it still consumes oil and that is likely caused by a ring or a valve guide;
then hone the cylinders, reinstall the pistons, replace the starter and the relatively new timing belt because it is a major job to do later and everything will be apart now.
This almost-major overhaul will cost around $3,000.00.
Good thing I am independently wealthy. Hah, hah.
Now would be the time. Is there anything I could do to improve gas mileage?
Is there anything I missed?
Pictures posted garyhgaryh General Maintenance and Repair 1 10-27-2007 07:57 AM
Volkswagen Diesel Quantum '84 zpiloto General Fuel Topics 10 06-14-2007 08:39 AM
Things To Look For When Buying A Civic Hx panamacolin General Fuel Topics 9 06-06-2007 08:43 AM
Hello People of Earth coastertoasterxb Introduce Yourself - New member Welcome 8 03-20-2007 05:56 PM
Thinking of buying a Fast car? Compaq888 General Discussion (Off-Topic) 10 01-09-2006 11:18 AM
